I’ve searched everywhere for this trick I discovered. Maybe it hasn’t been posted or put on YouTube because it’s so basic.
In the past I’ve struggled with levelling pins side to side because ZY does not put convenient horizontal lines in his playfield art. So a lot of the time I approximate a straight level line across the playfield to line my level up with. If I don’t get it perpendicular to the side rails I’m not getting a true reading.
So after years of struggling to work out how to get a straight level line across the playfield to line my level up with, I suddenly realised a really simple way of getting a correct level line.
Use the playfield glass. Pull it down so the top is level with where you want to measure. Look from above, line your level with the edge of the glass. You may want a second person to stop the glass from sliding out. Was the only way I could level GZ and DP.
