Two best features have on the hobby end are auto ranging, and audible beep continuity. I believe that multimeter has both? In that case I'd say it's fine.
Quoted from CNKay:For any pin work should be fine. You may find this video helpful.
This guy love it lol
Yes he has some great aussie slang, like half a bee's d!<k and bob's your uncle. One video he blows up several meters and takes Fluke through a canyon and throws off a dam. Lot of interesting and surprising vids.
The main points I wanted you to see were you want a fast continuity test, a large voltage for the diode test >2V, a good backlight and auto power off with good battery life. Safety he stresses which of course is something to consider and well your get what you pay for.
I know you can even pick up used Flukes on ebay cheap. Like Fluke 8060A back in 1990 was like 430.00 some i have seen for like 20. No autorange but great continuity test. Well you get the idea.
And remember whatever you get to "Take it apart".
I have that exact one. I love it.... But
I use the cheap free one from harbor freight when I am doing voltage cause I keep popping the fuse on the Radio Shack.
http://www.amazon.com/Mastech-MS8268-Digital-Manual-Multimeter/dp/B0050LVFS0/ref=sr_1_1
I have been using that one above^^^ lately. Overall it is very, very good for the price.
Quoted from maddog14:when I am doing voltage cause I keep popping the fuse on the Radio Shack.
Sounds like you have meter lead in wrong jack when you are trying to read voltage.
Common Jack black lead never moves and for Voltage and ohm/diode Red Lead is where you want the Red probe most of the time. And you always read voltage across two points but the meter has huge impedance so it does not effect the circuit.
If you have the Red Lead in the current jack (there maybe 2 low2A and high10A) very low impedance and fused. You need to put inline with a single wire. If you put across two points like measuring voltage you just made a dead short to ground and the fuse will blow every time. Current measurement not as easy to due quickly so not as often used. But say you want to see how much current is going through a coil when fired you could unsolder the ground wire of coil attach red to coil and black to the end you just unsoldered. It has to be in series. Always.
Quoted from maddog14:I have that exact one. I love it.... But
Your plugs aren't set up correctly. In voltage mode the meter ends up with very high impedence and is placed in parallel with the circuit. You shouldn't be able to pop the fuse if the plugs are installed correctly. The fuse is for current measurement and is in series with the circuit in that case.
Quoted from CNKay:Sounds like you have meter lead in wrong jack when you are trying to read voltage.
This ^^
This page was printed from https://pinside.com/pinball/forum/topic/good-enough-multimeter and we tried optimising it for printing. Some page elements may have been deliberately hidden.
