Cheers!
So... I got this goldeneye which had some issues, and its been stowed away in a garage for 1-2 years. All fuses were fine, and the bracket for the plunger coil was broken but apart from that it seemed fine.
Alas, have some issues on startup.
I noticed there is some battery acid damage around the battery, not too much but might be a problem.
When powering on, we get the gunfire sound which seems to get stuck in a loop.
Also the dmd is dead. Except when powering off, then i see some artifacts on the screen. Any ideas what moght cause behaviour like this?
Video is here:
