I've got a Gold Wings that has undergone MANY upgrades, such as the additional grounds, multiple "power good" LEDs, and even the ground upgrade for the power supply.
I also found several zener diodes bad that prevented several switches from working.
EVERYTHING is working great now, EXCEPT when the game starts, the balls kicks out to start play, but the ball just barely makes it into the shooter lane.
And then when you drain the ball, the next ball doesn't make it into the shooter lane.
I can hear it kick the ball, it just doesn't have enough OOMPH to make it the whole way.
So, question is... what is the most probably cause for this?
Something misaligned?
Coil needs replaced?
Switch needs adjysted?
Other?
