(Topic ID: 261050)
Gold Wings blows fuse after popping ball into the lane.
By Yeastlord
1 year ago
  • 10 posts
  • 5 Pinsiders participating
  • Latest reply 4 days ago by pinballboy
#1 1 year ago
I've got a Gold Wings and after starting a game it will pop one ball into the lane before blowing fuse F11. I tested the resistance on the solenoid and it looks good. I spent a bunch of time poking around and couldn't find anything obvious. Anyone have any ideas on where to look next? Is it possible that even though the solenoid tests ok it could still be bad and blowing the fuse?
Thanks in advance for the help!
#2 1 year ago
Did you look in the manual and see what fuse F11 is for?Solenoids very seldom ever go bad unless it’s fried/burnt.On that shooter lane switch is there a diode on that switch?
2 months later
#3 1 year ago
The manual says that it's the Ball Release, which I assume is the solenoid that drops the ball into the trough. I had a new solenoid so I swapped it in and I still have the same failure. I checked the leaf switches and they aren't stuck shut. Any other ideas?
#4 1 year ago
UPDATE - I was getting way out of bounds readings on the remote 2N5879 transistor by the ball release so I replaced it. Now the fuse blows as soon as the game turns on. This game hates me.
2 months later
#5 1 year ago
Quoted from pinmike:
F11 is for the solenoid that pops the ball into the trough. It doesn't appear to have a diode on it. I checked that the switch isn't stuck on or anything like that. It seems OK.
Any other thoughts?
#6 1 year ago
It is supposed to have a diode. Try that, and see if it makes a difference.
1 year later
#7 67 days ago
It's been a while but now I've got the time to really dig into this monster. So the resistance on the solenoid was super low (.6) so I replaced it and it's happy. The issue now is that switch 46 stays open after the ball is popped into the lane and it still blows fuse F11. I've been going through the schematics - and I'm definitely an amateur - but I haven't found a reference that tells me what switch 46 is. I know approximately that it's right by the solenoid I just replaced. Is it the bottle cap right behind it?
-Thanks everyone
#8 66 days ago
GTB uses diodes boards. The diode probably wont be on the coil itself.
1 month later
#9 18 days ago
More info - what appears to be happening is that the ball release solenoid is firing and locking on until the fuse blows. I changed out the solenoid with a new one (with a diode). Made no difference. Went over the driver board and metered all of the transistors and resistors. Everything was within tolerance. Cleaned all of the edge connectors.
Gave everything a visual inspection and didn't see any issues.
Anyone have an idea of where to look next? Thanks and Happy New Year!
#10 4 days ago
my gold wings used to have an issue just like that. make sure all connections to the solonoids, boards and connectors (including everything under the playfield) are solid. then if that doesn't work look for a short somewhere in the wiring. good luck
