New! Dark mode!
(Topic ID: 218076)
Gold Record won't start
By seeburg220
2 years ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by Chrisbee
#1 2 years ago
Chicago Coin Gold Record. : /
Credits on the credit wheel. : )
Credit unit switch verified closed. : )
Push the start button and nothing happens. : (
Looking at part of the schematic here, which direction is the process going - to the left or right ? The credit button is between the Start Relay and the score motor switch A-5. What should I be looking for here ?
#2 2 years ago
From a fault finding point of view, it doesn’t matter the left and right bit.
First thing, when you press the credit button, does the Credit reset RE energise?
If No, then with a DMM set to Ω and the power off, check for continuity from the thick common wire and the White/Orange wire at the credit button. If this is OK, then check for continuity from Black/White wire to Credit Reset RE Coil. You can check both sides of the coil; you will get different readings but still closed circuit.
If all this checks out OK, then check the credit SW for continuity when closed too.
If the first test fails, the issue is likely to be at the Start RE or Jones plugs ETC. If the 2nd test fails then you can break that side of the circuit in ½ and test again.
You are looking for Continuity from the common wire (left side of the above image) to the Coil power supply wire.(Right side)
TheDudeMods
$ 99.95
pinballmod
$ 28.75
The MOD Couple
$ 1,099.00
$ 7.00
$ 209.99
Metal-Mods
$ 68.00
$ 259.99
$ 36.99
Lee's Parts
$ 369.00
$ 9.50
£ 50.00
$ 98.00
$ 49.99
$ 24.50
$ 5,899.00
Classic Game Rooms
$ 24.00
Docent Electronics
Pinfarmer Mods
$ 48.00
$ 19.95
$ 26.95
€ 59.80
Lighting - Backbox
Freddys Pinball Paradise
Various Novelties
Pinball Photos
