First comes the tear down. The playfield had a full Mylar on it, not sure if it was stock, it did not leave behind alot of residue.
Main ramps removed. Plastic ramps are in good shape. A couple of tabs broken but nothing major or bad enough to be worth replacing.
Now to remove the rest of the plastics.
The back board decal had begun to curl up on itself and it's too brittle to fix. I have a new back board decal on the way. The police lights are also cracked but i was able to repair them and also have new police light decals. The plastics aren't great but I can't find any replacements except for the slingshots. Still looking to buy a plastic set if anyone knows where they can be found.
Judge Dredd is ready to be clearcoated. I wont go as far as removing the harness and light sockets. I will tape everything off and plug the sockets to avoid getting clear or overspray on anything.
Clearcoated and ready to be re-assembled. I let it sit for a couple weeks before putting it back together.
All the metal guides and posts have been polished.
I opted to go with orange rubber posts. So far it's looking really nice.
I rebuilt all the mechs and re-installed them .I also put leds in for all the inserts. Next comes the ramps and plastics and g.i. leds.
Alright!! Now I'm all caught up on this post and everything from here out will be in real time so updates may be a little slower.
This next picture was my inspiration and I hope in the end my JD will look as good if not better than it.
NOT MINE
NOT MINE
However I have already got all my brass parts in and even found this blank coindoor on eBay, it was alot cheaper than a complete one.
The picture makes it look darker than it is.
Quoted from Frippertron:Following. This was Keith Elwin's inspiration for Iron Maiden!
JD is a really cool Pin,I really enjoyed having one cool music,DCS sound,funny qoutes,and a lot more to offer my kids loved it especially when the guy falling off the roof!!(I can see my house from here!!)The smiles and laughs on the kids faces...Priceless...Thank God it's based off the comic book and not the movie.
There's an ad here on Pinside for 2 JD Pins I would love to pull the trigger on this one but not the right time,if it was years ago i would have jumped on it right when i seen it.
Looking nice, and i enjoy the gold on it alot! Kinda envious though since if i coat any metal on a pinball here in Sweden i get yelled at by purists
Quoted from Luzur:Looking nice, and i enjoy the gold on it alot!
If you like the Gold check out my first restoration. The "Gold Black Kinight"
https://pinside.com/pinball/forum/topic/williams-black-knight-playfield-swap-and-shop-out
Quoted from newtoit:If you like the Gold check out my first restoration. The "Gold Black Kinight"
Looked nice aswell, i did the same to my Gottlieb Arena (and yeah i got yelled at by purists) and it fit the theme real nice. (old pics though, so bad quality.)
Well that's about as far as I can go with the playfield for now.
So onto the cabinet. I have new decals and alot of gold!
The cabinet is solid but really faded. Its a shame I have to sand down this custom hand painted head, whoever did this touch-up did a fantastic job.
Quoted from kvan99:Following don't forget the gold flipper bats and red rubbers.
Originally I wanted to gold plate all the metal on the pf. But there is so much metal that I will not be doing thatdue to cost, well not yet atleast. So the flippers will be black with orange rubbers.
I'm in the middle of priming and painting the cabinet for decals will update tomorrow.
Quoted from cosmokramer:Did you paint your ground braid?
Yes but then I replaced it with a new ground braid.
Brilliant looking!
Can I add a thought... buy the pbl leg spacers... install them, razor around them and remove the decal behind them, re install the spacer.... install leg. No wrinkle in the decal.
As it stands you may have started the wrinkling process behind those black leg protectors.
Quoted from Chosen_S:Brilliant looking!
https://www.pinballlife.com/index.php?p=product&id=2711
Totally agree...would hate for your decals to wrinkle. Follow this advice ASAP!
Great advice. Will do.
Working out some kinks. I'd never turned it on before restoring it so I had no clue what issues it had. So far I've fixed switch matrix issue (my fault, I hooked up some connections wrong) lamp matrix issue. Replaced a couple opto emitters. Another switch issue, pins on driver board had solder cracks. And lastly the flashers don't work but i ordered a new capacitor for c11 it is bubbled on the top. Still waiting on parts for that.
Quoted from gunstarhero:Looking good!
Might want to install some balls in your Meltdown lane tho!
I want to get the neon green balls for the meltdown. I've seen it done and it looks nice.
Here's an example but blue.
Quoted from newtoit:I want to get the neon green balls for the meltdown. I've seen it done and it looks nice.
Do the reactor mod! You’ll love it
Quoted from Chosen_S:Do the reactor mod! You’ll love it
What is the reactor mod? I can't find anything about it.
Quoted from newtoit:What is the reactor mod? I can't find anything about it.
Nice job dude. Looks great, and JD is a sweet pin.
The reactor upgrade basically uses the cooling towers from TSPP. When lit up, they look fantastic. It requires a bit of surgery, but it may be worth it if you like the look.
Check the JD owners thread.
This page was printed from https://pinside.com/pinball/forum/topic/gold-judge-dredd and we tried optimising it for printing. Some page elements may have been deliberately hidden.
