(Topic ID: 297182)
Gogar: Smell something burning.
By Brewchap
2 years ago
  • 30 posts
  • 9 Pinsiders participating
  • Latest reply 2 years ago by Brewchap
#1 2 years ago
OK....here is what happened. Wife adds credits to Gorgar and went to play. The flippers locked on and a burnt smell filled the room. Then she called out to me to see what was going on and the pin is still on.
So power was on for what I feel was a long time. This is what I can tell so far. Game boots up, light work as they should. No coil is fried and seem to work.
When a game start, the sound is messed up. Hitting the diagnostics switch on the sound boards, all sounds sound good along with voice.
For the life of me, I can not find anything burned. I will know more tomorrow as I swap boards out. I got a working MPU and driver board to test with. Oh and power supply if needed.
Other then swapping out boards, what is the best approach to narrow down this problem?
#2 2 years ago
Quoted from Brewchap:
Start by using a DMM/voltmeter to measure all your power supply voltages.
#3 2 years ago
Thats a great suggestion. I did find the source of the burnt smell. Looks like Q14 (knocker) burned up. that coil is not burned up and the plunger moves freely in the coil sleeve.
The power on the power supply looks good.
38v for the flipper/solenoid
17.4v for the lamps
do not use the HV section
10.4v in the 5v section
Sound is still messed up. The heart beat is missing at start up. 3 high tone beeps is all that I hear.
#4 2 years ago
Re-check the 5V. 10.4V sounds impossible if the game still boots. All other voltages are OK. The flippers locking on is also strange, since they are not CPU controlled.
The sound board is controlled by driver board solenoid outputs. You might have some problem in solenoid driver circuitry (bad 7408 or PIA). But swapping boards should make it easy to locate the problem at board level.
Don't put any known good boards into the game until you verify the 5V to be correct (4.75 - 5.25).
#5 2 years ago
I was measuring at the fuse holder F5 to get 10.4v. So I measured at 3J6 this time and found that I have 4.78v. I tested on the 5V test point on the CPU and it had 4.75v.
#6 2 years ago
Flippers were locked on and now they’re not? I’m assuming you checked fuses, including under the cabinet. Along with transistors that lead to your coils. I’m not sure how that would effect sound.
#7 2 years ago
So your power supply is OK. The 5V could be a bit higher, but 4.75 is still in specs.
#8 2 years ago
I found Q14 burned up. I have not replaced it yet. For the time being, I cut the wire going to the Knocker.
I "good"back up board, will not get out of the Audit mode. So I am stuck trying to test the original MPU and Driver board. So for now the Pin boots up and plays, all coils but the knocker are working and I have sounds, just not the right sounds in some parts of the game. Also no heart beat that plays continually in the back ground.
As far as the flippers locking on at boot up, I'm guessing that there must have been a power surge at some point causing the flippers to kick on. And maybe some of the other coils kicked on too. Don't know... just a guess.
But I'm stuck on the why I lost certain sounds and how to get them back.
#9 2 years ago
The flippers locking on, wow... I could see controlled coils locking on, but the flippers? Both of them? On an early SS game like this where the power has to go thru the high-power flipper button switches? Yeah they are enabled via a relay by the CPU but that doesn't complete their circuits. Maybe she was mistaken about them actually locking on?
#10 2 years ago
Changing out the CPU and PIA did not make a difference.
#11 2 years ago
Changing out the driver board fixed the issue. Now I need to figure out what is wrong with the driver board.
#12 2 years ago
Flip it over. You probably fried the trace.
#13 2 years ago
Quoted from Mad_Dog_Coin_Op:
I just found it, IC4 got burned up. I didn't see it until I got the magnifier got. Replace it and it is working now. Something really shorted out. I don't think that I'm going to repair the knocker. It had a very low dud sound and besides Gorgar tells you when you win.
#14 2 years ago
Still have one more problem. Lamp column drive #5 is not working. Checked Q70 and Q71 and it did not test bad. Makes me wonder if IC14 is bad.
#15 2 years ago
Lamp column drive #5 still not working after checking Q54 and Q55. Even swapped IC17 and IC18 with no change.
#16 2 years ago
Ok, Out of frustration, I install the other Driver Board. It had the same problem with Column #5. Either I got the same problem with both Driver Boards or I got a playfield problem.
#17 2 years ago
Well, I thought that I would close this thread with what I found. I found that all the bulbs in column #5 had blown or melted.
#18 2 years ago
Wow, this is getting deep
#19 2 years ago
Good catch! That's the kind of problem where I would have tried every other possible thing first...then discovered all the bulbs were bad, lol. Sometimes you just gotta start with the easy stuff, but I know I'll make similar mistakes in the future
#20 2 years ago
Quoted from frunch:
//<![CDATA[
window.__mirage2 = {petok:"e2af429c6fc41a90d5cf44084ae0ccb2ca292476-1627066120-1800"};
But why are they melted?
#21 2 years ago
Appears to be excessive voltage to the lamps.
What is the voltage rating of those lamps?
#22 2 years ago
Quoted from Da-Shaker:
I would like to know that myself!
Quoted from G-P-E:
6.3v
#23 2 years ago
Is there any history to this machine? Did you have a power surge, change wall sockets or on generator?
#24 2 years ago
No history on the machine. it was dead when I got it over a month ago. No power surge, change of wall socket or generator. Been playing great since I got it working....till the other night when something shorted out.
#25 2 years ago
What did you do to get it working?
You could have a short within that light string, under the play field.
Possibly someone resoldered the board under one of the connectors and you have 2 solder joints touching each other. This can potentially damage one of your chips. Are any of your lamp driver board connectors burnt
#26 2 years ago
#27 2 years ago
Controlled lighting on Williams System 6 games is from an 18 volt supply that is switched through the lamp matrix at a specific rate so that the lamps see an average of 6 volts. If something happens to cause that strobing to stop, the lamps will see the full 18 volts.
#28 2 years ago
Quoted from MisterScappy:
Just chatting,
Could this happen because of a bad bridge rectifier that wasn’t fused? Which in addition could fry a lot more then a string of lights
#29 2 years ago
Or a bad capacitor on the power supply
#30 2 years ago
I had to rebuild a small section of the board due to battery damage. Replaced all connectors and headers along with the 40 pin connector. Also had to replace IC2 on the MPU board because of a difference solenoid problem.
$ 69.00
Pinball Pimp
$ 1.49
Daddio's 3D Printed Mods
$ 27.95
Newcastle, OK
$ 69.00
Pinball Pimp
2,900 (OBO)
Franklin, VA
$ 170.00
Displays
Digipinball Shop
$ 42.95
$ 12.50
RoyGBev Pinball
$ 40.00
The Flipper Room
$ 859.00
Tools
Pincoder Store
This page was printed from https://pinside.com/pinball/forum/topic/gogar-smell-something-burning and we tried optimising it for printing. Some page elements may have been deliberately hidden.
