(Topic ID: 315984)
Godzilla “Tokyo Neon” sign mod (*extended run*)
By stumblor
1 year ago
13 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 1,658 posts in this topic. You are on page 11 of 34.
#501 1 year ago
Quoted from stumblor:
Yes that's right. The right hand 'sign' part in English runs a constant 'glitter' type effect with low intensity to make the sign look like its lightly sparkling. Since that section is also addressable there's no reason it couldn't also change depending on the current mode - at the moment I don't feel there is a need to, but it's provisioned that way just in case.
I assume that's not something configurable right? And I assume your code is closed source so that's not something we can tweak?
#502 1 year ago
Quoted from Sorokyl:
All the patterns & colours are configurable over WiFi, and there's a ton of scope for tweaking it to your tastes. Currently the right-hand sign section can have its base pattern & colour modified, but isn't triggered - however this could be added easily enough in a firmware update later if there was enough demand for it. The firmware itself is closed source, and is a branch of my Lollypops code. For a brief rundown of how this works, checkout the quick start guide here:
This is all coded by me - it isn't a third party tool like WLED - so although its closed source, I'm more than happy to discuss changes, improvements, or additions. Hit me up!
#503 1 year ago
Judas this thing keeps getting better and better....
Couple more mods and you will have to start working on your own light show pin machine wowza
#504 1 year ago
Add me to the list please.
#505 1 year ago
I’m in!
#506 1 year ago
Please add me. Thanks!
#507 1 year ago
really fantastic awesome mod ,
please add me to the List , i am in
ty
#508 1 year ago
Quoted from Colywobbles:
I was lucky enough to be one of Stumblor’s beta testers for his Tokyo Neon Sign Mod so I thought I’d post a little video of my experience fitting the mod hope it’s some help to those lucky enough to have their name in one.
Please note photos and videos don’t give this mod the justice it deserves and it looks far nicer in the flesh and the way it shimmers and flickers is just mind blowingly awesome.
Please excuse the broken arm but it does go to show how easy it is to fit 48hrs after an operation which involves having a plate and 8 screws put in my arm due to the bad break.
Had a drive up to see Colywobbles today and part of it was to check out @stumblors neon sign.
From someone who doesn't own a Godzilla this just goes with the theme and playfield so well.
One of them mods that look factory which is what we all want when adding things to our machines.
The lighting effects are superb on it and make it easy to see whats highlighted while your playing.
All you guys on the list will be extremely happy when you get to see this in your games.Sample videos just don't do it justice.
Well done stumblor
#509 1 year ago
#510 1 year ago
I love this sign! Please add me to the list. Thanks!
#511 1 year ago
Put me down please. Great job!
#513 1 year ago
#514 1 year ago
Please add me to the list!
#515 1 year ago
Plus 1 more to the next run list for me THX
#516 1 year ago
Even though it'll be a LONG wait, please add me to the list.
#517 1 year ago
Any thoughts on a 3 piece sign set yet? LOL
#518 1 year ago
Quoted from DeathHimself:
I believe he is working on the rear buildings and those will have the signs as part of the design. All I can say for sure is, I cant wait to install my sign! Such an amazing mod!
#519 1 year ago
Its definitely coming!
#520 1 year ago
I'm all in............... Just add me now
minus the scoop sign as I'm already #64 on that list.
#521 1 year ago
Can you add me?
Thanks.
#522 1 year ago
Loving the enthusiasm but going to wait until we announce something before taking names for that one. I'm all listed out at the moment.
#523 1 year ago
I was wondering if you were going to make the second sign in the back too! it’s going to be jaw dropping with both signs lit up. I can’t wait.
#524 1 year ago
Looks great. Please add me. thanks!
#525 1 year ago
PM sent, please add me to the list! Thanks.
#526 1 year ago
Can you please add me to the list? Thanks!
#527 1 year ago
Please add me to list. Thank you
#528 1 year ago
J85M and Colywobbles fix up look sharp - time to do some beta testing!
Everything still on track for mid July at the moment. In the meantime I've been refining the code, ironing out a few niggles, and testing like crazy. Second run is filling up - still around 100 places left (out of 250). Absolutely incredible. I'm super happy, but at the same time laser focused on living up to that expectation.
Pinball is rad!
I can confirm that Davey (stumblor) has hit a home run with this thing!
Baring in mind this is just a proto and improvements have already been made to the next/final revision the quality is absolutely first class this is not your typical off the shelf mod with a couple of LEDs glued into it.
Easy enough install and once it’s up and running the customisation direct from your phone or tablet (whatever you connect to it with) is pretty much endless!
You can make it as simple to understand as the factory sign, so there is no worry of it being confusing or set the light show so the sign goes nuts when you have battle, power up or ally qualified or active.
And it looks bloody when your games powered off too.
Oh and it’s worth also noting, no pictures I took did the sign any justice, when you have it set up and personalised the way you want it the whole thing is just stunning and a joy to watch,
I went with red/yellow animation for battle, green/neon green animation for ally and blue/ice blue animation for power up, when they where ready at the scoop and then a solid lit colour once collected/started.
P.s. Davey are any of the sequences/settings a slow pulse? I’d love to be able to set a slow pulse of two colours, that would change between the two colours with each pulse.
3A8414DB-BDC1-45C5-BD14-E3E4B69C573B (resized).jpeg3A8414DB-BDC1-45C5-BD14-E3E4B69C573B (resized).jpeg7A85B571-8557-47D9-8622-2FFCA112856A (resized).jpeg7A85B571-8557-47D9-8622-2FFCA112856A (resized).jpeg
23
#529 1 year ago
Production begins!
On the advice of Sorokyl I have recruited a small force of very vocal small handed workers. Unfortunately she asks for way too many sausage roll and roblox breaks. I would fire her but not sure how I'm fixed contractually...
^^ Checkout the sleeping kitten in the plant pot
Cabling and production PCBs are due to arrive next week. Once they do and I've had a chance to test everything I'll be send out PMs to the first 50 people, and then moving on the the rest of the first batch quickly after that. I'm on holiday start of August (our yearly family trip to Ibiza!) so hoping to get a good start on everything before that.
Nearly there!
#530 1 year ago
Teach the cat to help!
#531 1 year ago
Quoted from Only_Pinball:
As long as everyone could deal with their signs smelling a bit like tuna, that just might work!
#532 1 year ago
I will beta test the cat built version!
#533 1 year ago
Hello add me to the list to get a sigh
#534 1 year ago
Thank You.
#535 1 year ago
Production begins!
Nearly there!
That, is exciting!
By my shoddy counting I am about 120 ish on second runs.this is one worth waiting for!
#536 1 year ago
Quoted from Shuoink:
That, is exciting!
#405 overall so you were close! (the list is now been added to the first post).
#537 1 year ago
I was interested in supporting this project until I saw child labor being utilized. Shameful ! Lol
#538 1 year ago
Couple of new improvements to the code while I wait for the last parts shipments to arrive:
1. On board firmware updates. No more having to download the bin file onto a separate machine and upload - the sign is now capable of connecting to the internet, checking for updates, auto downloading, updating, and installing.
2. Pattern Naming. J85M mentioned that it was sometimes hard to remember which pattern was which based on the numbering alone. I agree! Now they can be given a descriptive name.
#539 1 year ago
Quoted from Gman3:
Child labour is the least of your worries - we now have a fully automated feline labour force!
#540 1 year ago
Finally, a use for cats. Sorry, couldn't resist, I'm a dog person.
#541 1 year ago
Tha ka for updating the list!
What saucer mod is that in the pics?
Ty
#542 1 year ago
Ty
That's the Jazzbouche saucer lit and triggered by one my Lollypops LED rings. Better video of it here:
https://pinside.com/pinball/forum/topic/stern-godzilla-mod-thread/page/31#post-6924059
We're planning on releasing these as a kit (UFO + triggered lighting, 2 x triggered RGB post lights, 1 x triggered backbox godzilla breath) in a few months time.
#543 1 year ago
You know I want on that list
#544 1 year ago
Quoted from Jamesays:
You're number #3 already mate, right behind the beta testers!
#545 1 year ago
Can I get bumped up the list for the idea?
#546 1 year ago
Well dang... I was going to get a different one but I probably have to get on that list now too...
#547 1 year ago
First 50 people contacted today - check your PMs!
#548 1 year ago
#549 1 year ago
#550 1 year ago
I'll take one too!
$ 540.00
Duke Pinball
Decorations
$ 115.00
Raiden Mods
Toys/Add-ons
$ 28.50
Toys/Add-ons
Toys/Add-ons
$ 185.00
Raiden Mods
Toys/Add-ons
$ 125.00
Cabinet - (Alt) Translites
PINBALLPICKERS
(Alt) Translites
$ 125.00
Diddy's Pinball Mods
Toys/Add-ons
$ 19.95
Pin Monk
Other
Mad Pinball Shop
Chrome Candy
Protection
$ 104.00
Toys/Add-ons
Volcano Pinball
Protection
$ 120.00
Duke Pinball
Decorations
€ 110.00
Pino Pinball Mods Shop
Toys/Add-ons
$ 79.95
Hookedonpinball.com
Shooter rods
Space Coast Pinball
6,500 (Firm)
Fort Wayne, IN
$ 399.95
Pin Stadium Pinball Mods
Led
Pinhead mods
Protection
€ 95.00
Toys/Add-ons
$ 27.00
Chrome Candy
Toys/Add-ons
6,500 (Firm)
Los Angeles, CA
9,100
Collinsville, IL
$ 44.99
Pinball Shark
Shooter rods
Filament Printing
Other
Precision Pinball prod.
Flipper parts
€ 168.00
Lighting - Backbox
Watssapen shop
Backbox
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/godzilla-tokyo-neon-sign-mod/page/11 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
