Hey Everyone
I’m Jazzbouche – I make Mods from time to time (a few of you may know me from such mods as the IJ Bumper Cap Ruins and Medallion Jackpot. ) but I’ve recently been working with Stumblor on his awesome Godzilla Lolly UFO kit. In between seeing images of those damned UFO’s in my sleep, I’ve been working on a new Godzilla…one that fits with the playfield art…one that maximises the space by the building…one that has interactive light effects with the game!! So here it is….I hope you like it!
Obviously it could only work by integrating Stumblors now legendary kit, and in this case we decided the Lolly G.I was the way to go. Allowing you to connect any input as the trigger to cause Godzilla’s spines and face to go atomic!!
There will be two available sets:
1) Atomic Godzilla Basic, with integrated Lightstrip but NO LOLLY G.I. I repeat – this version does NOT come with the board to make it light up! ‘Why’ I hear you ask?! Because some of you may choose to plug him into your existing ‘LollyUFO’ kit via the backboard connectors. However, this will have the limitation that he will mimic whatever lighting effects and triggers you have setup for your backboard.
PRICE….£180 (currently $211 subject to the exchange rate) plus shipping
2) Atomic Godzilla Extended, with integrated Lightstrip AND Lolly G.I. This is recommended and will give you full control to set Godzilla’s triggers and effects however you wish. With Lolly G.I you can set any switch (newton Ball, spinner), insert, flasher, or coil as a trigger to activate lighting effects along Godzillas spine and eyes/mouth. The lighting effects are fully RGB and configurable for different patterns over WiFi. Check out more detailed info here: https://stumblorpinball.com/products/lolp or here: https://stumblorpinball.com/docs/lolp
PRICE….£220 (currently $258 subject to the exchange rate) plus shipping
Other notes worth mentioning – these are resin printed, hand finished, and hand painted. They will come with a new clear plastic to swap with the one in you machine that currently has your Godzilla figure attached to it. You’ll need to unscrew your existing Godzilla and screw Atomic Godzilla to your new plastic and re-install.
I’m planning batches of 50, no pre-payment required – you only get invoiced when your spot is ready. Post on here if you want one and you’ll be added to the list in order.
Paul (a.k.a Jazzbouche’s Mojo Mods)
____________________________________
Original list (now completed):
Reserved...................... 1
Reserved...................... 2
thekaiser82................... 3
SR230CC....................... 4
eyeamred2u.................... 5
DVDA.......................... 6
Gd2103........................ 7
dzmechanical.................. 8
Leechman...................... 9
dgposter...................... 10
mbott1701..................... 11
Sjoend........................ 12
scottr........................ 13
GorillaBiscuits............... 14
Skatewake..................... 15
Sjolund....................... 16
mtopol01...................... 17
Wmsfan........................ 18
qbass187...................... 19
galore2112.................... 20
PDX-Mike...................... 21
Kevin_LHeureux................ 22
ulmpharmd..................... 23
Mtg381........................ 24
mzhulk........................ 25
Sixxin........................ 26
bane.......................... 27
TOOLPRO....................... 28
matt_assassin................. 29
bajm.......................... 30
prentice...................... 31
McDoom........................ 32
spidey........................ 33
Vino.......................... 34
mtp78......................... 35
RoadQueen..................... 36
TimetravelPin................. 37
rmbakos....................... 38
Had........................... 39
Zora.......................... 40
surfinvet..................... 41
mslow......................... 42
tatman9999.................... 43
Pinball-Obsessed.............. 44
inhomearcades................. 45
Mackley....................... 46
fuseholder.................... 47
ticktockman................... 48
marioparty34.................. 49
brianbox...................... 50
CloudHearts................... 51
Shuoink....................... 52
jackd104...................... 53
RikeIsland.................... 54
Lordanubis.................... 55
greenmonk..................... 56
Method_Own.................... 57
LeMansFan..................... 58
Bjlj.......................... 59
ToucanF16..................... 60
VanSkalen..................... 61
Vegasbills.................... 62
Vegasbills.................... 63
Tomshine...................... 64
Ramzr1........................ 65
Pinballpal.................... 66
Vinnyblanc.................... 67
Cwells3290.................... 68
TheGunnett.................... 69
sleepless..................... 70
seebobble..................... 71
SerenityNow................... 72
rgzpinx....................... 73
ptrav1........................ 74
mtntrek2...................... 75
hendrikpohl................... 76
pingod........................ 77
Sixtieskid.................... 78
djsolzs....................... 79
brucea1956.................... 80
NC_Pin........................ 81
drewthegator.................. 82
St0n3PiraT3................... 83
frogger....................... 84
Bangback...................... 85
Ashram56...................... 86
Blakester..................... 87
RGman......................... 88
OSUBuckeye98.................. 89
SteelNation................... 90
6S3NC3........................ 91
Charliew65.................... 92
ThePlumber.................... 93
Paseb......................... 94
Vyzer2........................ 95
Fiddler....................... 96
Kkoss24....................... 97
Razzz......................... 98
Vitty......................... 99
Otto110....................... 100
Stevemoerke................... 101
friscopinball................. 102
bigdaddy07.................... 103
Wes62......................... 104
arzoo......................... 105
Aquapin....................... 106
Tvpinballs.................... 107
chrismillsmusic............... 108
rapidraw...................... 109
matlynch91.................... 110
Jackalwere.................... 111
smokinjoe73................... 112
ozno.......................... 113
marvinmax..................... 114
frenchman..................... 115
Skippy2904.................... 116
Jkaping....................... 117
deveric....................... 118
wagpinballz................... 119
WizzardRob.................... 120
Jenkins....................... 121
deleted....................... 122
Veemonroe..................... 123
cooked71...................... 124
blairan213.................... 125
Pinz19........................ 126
blubboman..................... 127
RebelGuitars.................. 128
truemagoo102.................. 129
pinsplit...................... 130
Jimmyhonda.................... 131
eharan........................ 132
SIKC7......................... 133
GranpaDave.................... 134
GranpaDave.................... 135
iepinball..................... 136
arock......................... 137
Charger68..................... 138
IncredibleVortex.............. 139
Jamieryan71................... 140
MarklarD...................... 141
PinBalt....................... 142
Fezmid........................ 143
chipleader.................... 144
Hershy........................ 145
jbigdoggf..................... 146
Marangsanz.................... 147
Tuna_Delight.................. 148
pin42......................... 149
adsnems....................... 150
jkashani...................... 151
J-Freeze...................... 152
Minnpin65..................... 153
TroyS......................... 154
venom112...................... 155
twb999........................ 156
james95t...................... 157
vgatchaman.................... 158
Duster72...................... 159
Jodannar...................... 160
drbrain....................... 161
Master_of_Trolls.............. 162
FalconDriver.................. 163
mavantix...................... 164
Deegs......................... 165
Derfone....................... 166
CashMoney..................... 167
Whargoul...................... 168
Norcalpin..................... 169
Jj557......................... 170
Josh0979...................... 171
swinks........................ 172
ccbiggsoo7.................... 173
Turtlemaster.................. 174
xeneize....................... 175
jamieflowers.................. 176
Alansavicki................... 177
Trogdor....................... 178
Nonox......................... 179
mmetsikas..................... 180
Lateralus..................... 181
Jkush18....................... 182
Kretinou...................... 183
Mattamoose.................... 184
zaker......................... 185
hockeymag8.................... 186
Mank.......................... 187
playcubeman................... 188
BC_Gambit..................... 189
MANTO1975..................... 190
PinDon........................ 191
NinJaBoot..................... 192
LDP84......................... 193
Blakester..................... 194
vincz......................... 195
TonyVrd....................... 196
taz16......................... 197
Haus7878...................... 198
CadillacFan................... 199
OrilliaPin.................... 200
Silvabullet................... 201
sroelens...................... 202
stormryder78.................. 203
tampa12....................... 204
Binos......................... 205
rvdv.......................... 206
kawafr........................ 207
Mavrik8511.................... 208
kklank........................ 209
Wamprat....................... 210
boostedskex................... 211
rmongold...................... 212
plasma........................ 213
BurntOffering................. 214
sleepygtr..................... 215
Geddy2112..................... 216
legionsoup.................... 217
deleted....................... 218
rodcom........................ 219
Grisbane...................... 220
doghouse...................... 221
BlueIrocGuy................... 222
jobowens...................... 223
Pinicus....................... 224
marksf123..................... 225
aslong132..................... 226
rapidraw...................... 227
Jvader........................ 228
KingofMars.................... 229
Blakester..................... 230
Blakester..................... 231
DoCPooF....................... 232
play_pinball.................. 233
James230376................... 234
Gooch......................... 235
P4plenty...................... 236
falky......................... 237
acupunk12..................... 238
PJZDJ......................... 239
Legros........................ 240
TeamUp........................ 241
Fiddler....................... 242
Dexter........................ 243
ffsRusMan..................... 244
Jimsheffield.................. 245
Jimsheffield.................. 246
rwh143........................ 247
NoDisclaimer.................. 248
deleted....................... 249
deleted....................... 250
deleted....................... 251
Alexis78...................... 252
Mindcrime..................... 253
phalcon_2600.................. 254
stuckey_t..................... 255
pbjksb........................ 256
Sluggo39...................... 257
Spectreman.................... 258
playtowin..................... 259
phs4real...................... 260
CoinGuyNinja.................. 261
CodeMonkey.................... 262
Fredouil...................... 263
jawjaw........................ 264
JayToo........................ 265
C-Note........................ 266
DerGoetz...................... 267
NewForestPinball.............. 268
Gudfala....................... 269
sepins........................ 270
arizonapinhead................ 271
Huckhappy..................... 272
BakedPsychopath............... 273
Atlantis...................... 274
T3quila....................... 275
Gube637....................... 276
itshowtime.................... 277
taz16......................... 278
El_Tizzle..................... 279
Analogkid..................... 280
marky7seven................... 281
IanW.......................... 282
Bodyman2111................... 283
triplemercman................. 284
tbanthony..................... 285
JC2137........................ 286
dkrubis....................... 287
Gigman86...................... 288
pbboy......................... 289
evanc......................... 290
Markjwilliams1................ 291
Acariya....................... 292
SigmundFloyd.................. 293
behrmr........................ 294
DeadlyVermin.................. 295
eas020802..................... 296
Simon78....................... 297
Sashbee....................... 298
Kannett....................... 299
foobeer....................... 300
john-from-az.................. 301
Oilrat........................ 302
badfish981.................... 303
Tophervette................... 304
bbble......................... 305
dbzap19....................... 306
CurtisC....................... 307
roscoepinball................. 308
Cyb3rPunk..................... 309
Proton124..................... 310
pit3239....................... 311
Pinhead1982................... 312
Whiteviper87.................. 313
danastude..................... 314
gandamack..................... 315
Barthalamu.................... 316
Nikko......................... 317
Mdanielb...................... 318
cosmo187...................... 319
thommo........................ 320
Tykwondo...................... 321
Aldie......................... 322
Voltar........................ 323
SeikoKid...................... 324
pinballmomPA.................. 325
nwood......................... 326
adamross...................... 327
1980Galaxy.................... 328
deleted....................... 329
deleted....................... 330
reffob........................ 331
MJK-911....................... 332
autopro....................... 333
brett......................... 334
AttilaK....................... 335
C-Note........................ 336
MasterOnion5.................. 337
Wms4ever...................... 338
DodgyMal...................... 339
Blenderhead................... 340
Blenderhead................... 341
Rotorwingflight............... 342
Boudu74....................... 343
Cs220877...................... 344
tayebl........................ 345
Kreyke........................ 346
Bazza......................... 347
DodgyMal...................... 348
JJONA......................... 349
tonyf1965..................... 350
Mjt311........................ 351
toro1966...................... 352
CQQLKAT-LEE................... 353
adamross...................... 354
Kelsbells..................... 355
Hellotim...................... 356
50SOC......................... 357
twinmice...................... 358
Baggerman..................... 359
Clovenhuf..................... 360
ManBarePig.................... 361
redman822..................... 362
diamondgrind.................. 363
Hairbear...................... 364
Teo76......................... 365
Belvedere..................... 366
Plasma........................ 367
THammons...................... 368
Pinball-Cruiser............... 369
zucot......................... 370
hansi2001..................... 371
Boosinger42................... 372
JEM........................... 373
bobcatgrl..................... 374
Hwawonyu...................... 375
Ronsplooter................... 376
apexsl........................ 377
Kingzilla..................... 378
Zen_Monkey.................... 379
Gambit3113.................... 380
McNick........................ 381
klbonn........................ 382
EricInAlaska.................. 383
FellBeast..................... 384
fraustl....................... 385
thpletcher.................... 386
EMpin......................... 387
Zeldarioid.................... 388
VolitionFlipper............... 389
NovaCade...................... 390
scpinhead..................... 391
hcj13......................... 392
Peepsdaddy.................... 393
zephee........................ 394
whitebreadisu................. 395
FarmingforPins................ 396
Nds777........................ 397
marspinball................... 398
Pin-Geo....................... 399
demandecan55.................. 400
anago......................... 401
pballinhd..................... 402
dabear007..................... 403
Nappis........................ 404
Tarheel4985................... 405
Wild_duck..................... 406
toro1966...................... 407
TheMediaDude.................. 408
Sijcolo....................... 409
McSirTuna..................... 410
falcontoys.................... 411
Wilberto757................... 412
Guillomm69.................... 413
Chilly........................ 414
The_Sko....................... 415
Texasff78..................... 416
Chewable...................... 417
DJShooter..................... 418
Conrad........................ 419
estrader...................... 420
TheDude227.................... 421
TysonChicken.................. 422
john_woods.................... 423
IBARAKURO..................... 424
matlynch91.................... 425
pokerag2...................... 426
bobts68....................... 427
Zablon........................ 428
Knucklehead................... 429
Richard45..................... 430
train33man.................... 431
ElevatedPanic................. 432
Corntaters2................... 433
kingau........................ 434
ColoradoJordan................ 435
Viperbsd...................... 436
adamforpresident.............. 437
TheBeefSupreme................ 438
etien......................... 439
Dragonfiredog................. 440
HighScoreRIC.................. 441
rkelley17..................... 442
JonnyBravo.................... 443
M055781....................... 444
KING-HENRY.................... 445
JeepSnob...................... 446
nielsvrijn.................... 447
Rocket600..................... 448
RussellWright................. 449
Dany41........................ 450
GCS2000....................... 451
Bruceh........................ 452
kwan8......................... 453
Jambo17293.................... 454
TheManNameSledge.............. 455
JayH.......................... 456
rai........................... 457
Indypin....................... 458
tgarrett09.................... 459
Scott-UK...................... 460
discosucks.................... 461
Trojanlaw..................... 462
RyanMaggio.................... 463
adbutche...................... 464
lakerone...................... 465
Busaturbo..................... 466
Pinball-Pete.................. 467
TheSaint025................... 468
ebrad90....................... 469
JohnMooch..................... 470
PantherCityPins............... 471
Hershmeister.................. 472
v-Skippy...................... 473
ManBarePig.................... 474
mcubed........................ 475
JDog3000...................... 476
MrMcPineapple................. 477
Cheeks........................ 478
LIST NOW CLOSED
Overflow List 1 (now in production):
jorshali...................... 1
MrFixxx....................... 2
wood20........................ 3
Darkfader..................... 4
Vinifromchicago............... 5
Strohz........................ 6
Aurium........................ 7
May........................... 8
Legewein...................... 9
Scott8806..................... 10
Waterdog...................... 11
drttd......................... 12
Hoss_Coog..................... 13
gb............................ 14
PinballHiro................... 15
TPMF.......................... 16
MNPinner...................... 17
CarpenterKris................. 18
Marangsanz.................... 19
rwalters21.................... 20
petersonjandrew............... 21
Screwloose.................... 22
Dalinar....................... 23
Asael......................... 24
reefer123..................... 25
Spidey66...................... 26
jcg9998....................... 27
Moli410....................... 28
ShrinerDave................... 29
Pitou19....................... 30
bmunn1........................ 31
Cooneysm96.................... 32
pbjksb........................ 33
J_Striker..................... 34
Rensh......................... 35
Arcadecrazy................... 36
Salami_Inferno................ 37
Donsacto...................... 38
bmblrb........................ 39
SiN13......................... 40
ktcoady12..................... 41
thegrunta..................... 42
Wray.......................... 43
joelbob....................... 44
Mamieu........................ 45
acidburn...................... 46
SylentK....................... 47
Bedrock84..................... 48
DrPins........................ 49
equan911ts.................... 50
Bigtito-68.................... 51
bballfan...................... 52
Jousley....................... 53
ThePinkMonkey................. 54
nwood......................... 55
davedecrom.................... 56
PlagueMarmot.................. 57
Garulflo...................... 58
Spelunk71..................... 59
WestCoastAussie............... 60
Tres.......................... 61
Tres.......................... 62
WildRover..................... 63
Pin_Jim....................... 64
Conrad........................ 65
Conrad........................ 66
mowensesq..................... 67
PinDon........................ 68
Charliew65.................... 69
Bellagio...................... 70
adamross...................... 71
missnyancat................... 72
brian36chambers............... 73
Pyropro....................... 74
Hulkbuster.................... 75
Hulkbuster.................... 76
Deadrock...................... 77
SerenityNow................... 78
leonml........................ 79
stormryder78.................. 80
GotTofu....................... 81
dtrimberger................... 82
RetroGamer74.................. 83
RetroGamer74.................. 84
Jeff82........................ 85
dkeys613...................... 86
deleted....................... 87
bmassarani.................... 88
bender........................ 89
leonkatze..................... 90
Thor_Odinson.................. 91
Apuguy........................ 92
DTSC.......................... 93
weaverj....................... 94
JudgeDredd.................... 95
PinstarNOLA................... 96
Texasff78..................... 97
TheBananaPeel69............... 98
Pinball559.................... 99
joeyd13....................... 100
Mapalot....................... 101
Enigma311..................... 102
anve.......................... 103
nickrivers.................... 104
stompeN....................... 105
JohnMooch..................... 106
ckorth........................ 107
Requis........................ 108
Djahvy........................ 109
TonyVrd....................... 110
DrB777........................ 111
bbulkley...................... 112
Meadows22..................... 113
Myurochko..................... 114
BKPitmaster................... 115
Steve-1973.................... 116
1967Firebird.................. 117
Djahvy........................ 118
Grr-pinball................... 119
maxharvard.................... 120
ZIMSPIN....................... 121
Bt67.......................... 122
Brianjemt..................... 123
Bacondaddy.................... 124
OldMrD........................ 125
shaggy4u...................... 126
fsumassey..................... 127
oneofgrace.................... 128
Ghostcri...................... 129
Zneagym....................... 130
equan911ts.................... 131
Altis7........................ 132
Joshjurg...................... 133
Trianglekicker................ 134
Parsec32...................... 135
dak........................... 136
Woowee........................ 137
xlbtflip...................... 138
Pomz.......................... 139
j_m_.......................... 140
HHDad......................... 141
Collm096...................... 142
Pinball-Cruiser............... 143
MarkA......................... 144
alex.......................... 145
LIST NOW CLOSED
Overflow List 2 (parts ordered):
polarzing..................... 1
Techneq....................... 2
BeeGeeMtl..................... 3
AlexisRose.................... 4
stphung....................... 5
djh00000...................... 6
TwentySide.................... 7
Collm096...................... 8
Greyhound..................... 9
LanternShark.................. 10
Chris74....................... 11
AnTKoch....................... 12
Funky_Chimp................... 13
Zaquar........................ 14
Kev60......................... 15
quirkb5....................... 16
Cory42........................ 17
nicksbrain.................... 18
TurboSmasher.................. 19
Sertx......................... 20
scylla........................ 21
Fredfrance.................... 22
redbeard...................... 23
wood20........................ 24
Penguindad.................... 25
andrewket..................... 26
dougPDX....................... 27
Leaftail...................... 28
Wilmmr........................ 29
ArcadeFix..................... 30
drwicket...................... 31
BrettB........................ 32
rshofcols..................... 33
Bulla......................... 34
Vara.......................... 35
NovaCade...................... 36
HomeArcader................... 37
EelcoHo....................... 38
tootallpilot.................. 39
Mand0......................... 40
rockola2stern................. 41
jyeakley...................... 42
Glennw........................ 43
limlannt...................... 44
DrHfuhruhurr.................. 45
Princev911.................... 46
pinballmlb.................... 47
Romezilla..................... 48
Azrubal....................... 49
OceanArcade................... 50
Hadojae....................... 51
Boss78........................ 52
DoctorSpeedy.................. 53
Mjesposi...................... 54
Jbeck1971..................... 55
PinballDude89................. 56
Time4akshun................... 57
Nicoli125..................... 58
Sjudkins...................... 59
Cschulte88.................... 60
DrKWS......................... 61
MultiballMark41............... 62
Chopplebrains................. 63
Chromanion.................... 64
elliot28...................... 65
drainbot...................... 66
BeeGeeMtl..................... 67
ivory368...................... 68
Mylstar....................... 69
wigletbill.................... 70
bajm.......................... 71
Discosaurus_Rex............... 72
Jcavonpark.................... 73
freegame450................... 74
CYpass........................ 75
toaster777.................... 76
Livin......................... 77
Romezilla..................... 78
Mwaltersva.................... 79
zxspectrum16k................. 80
Jbeck1971..................... 81
Dickey66...................... 82
kidspam....................... 83
PIPS.......................... 84
Anubis330..................... 85
OlyPacific.................... 86
ToucanF16..................... 87
Gusto1980..................... 88
DragonRR...................... 89
EStroh........................ 90
Hogey......................... 91
NotAWiz....................... 92
Jdkale........................ 93
WB2000........................ 94
pcb355........................ 95
ZIMSPIN....................... 96
exflexer...................... 97
malignx....................... 98
Homebru....................... 99
whatarush..................... 100
LIST NOW CLOSED
Overflow List 3 (planned for 2024):
Klemp......................... 1
OB619......................... 2
Klemp......................... 3
GiumGium...................... 4
Blueaway...................... 5
Sammer........................ 6
StupidJackpot................. 7
Blueaway...................... 8
ThinkFordFirst................ 9
Worldwind..................... 10
salbol1....................... 11
steverick2.................... 12
staceyflip.................... 13
Shane75....................... 14
PBatt......................... 15
Matsurigatzu.................. 16
billyd333..................... 17
junkyard...................... 18
Dukeblue02.................... 19
Livin......................... 20
Kabball....................... 21
DickWalker.................... 22
bbrian170..................... 23
OreoFlapjacks................. 24
bwalter....................... 25
PinPickle..................... 26
Code_Wookiee.................. 27
