I have just completed a build of goDMD with the VET6 controller (designed by steve45 , https://go-dmd.de/). It's really awesome and I highly recommend it whether you build it yourself or just buy it plug & play. It works quite well with the exception of one thing - being able to use your own custom true color animations. I was able to use custom 16-color animations and they worked fine except the colors displayed by the DMD were not correct. On the recommendation of lucky1 , I converted the animations to 24-bit color using the Editor, and that made the colors display correctly, but now the first animation to play will repeat itself indefinitely and never switch back to the clock or any other animation. Another side effect is that the PIR function that would normally turn off the clock after a set time no longer functions correctly either. I have generated the animation file (foo.ani), using all the various settings in the menu including all 6 "ani format versions" and the get the same result regardless. So, I am stuck and looking for help from steve45 or anyone else who might be able to advise of what I may be doing wrong or suggest something I might try to get it working properly. Here is video of what it does. There are 3 true color animations on it, but as stated it gets "stuck" on the first one.
