Well, I seriously doubt that is a part that is available to order. Would be best just to fabricate your own.
If you can find a stainless steel hose clamp that is the right width, you could cut it (tin snips), straighten it and bend it into shape pretty easy. You would have to drill the mounting holes and unless you are set up to rivet, attach the light with a screw and nut. The stainless will shine up like chrome.
I'd guess that the bracket section on some of the B/W wire gate assemblies that are available would fit with minimal alterations needed, but might be difficult to find the best match without being able to see it.
Thanks... Basically I want to remove the lamp sockets altogether because I'm tired of the bulbs getting knocked out on occasion during game play.... Gonna use 3 Led adhesive strips under the bracket shining down on ramps instead ... I don't want to destroy anything stock so it would be easier to just buy/make extras..... Idk, seems like a good idea to me if not I want to make easy to put back
I Appreciate the ideas
Quoted from dsuperbee:Dude, just use shrink tubing or a dab of glue from a glue gun for the LEDs. Problem solved.
Tried the glue... Lasted 2 weeks instead of one.... . Pisses me off!
This page was printed from https://pinside.com/pinball/forum/topic/gnr-r-ramp-lamp-lane-bracket-part-number-see-pic and we tried optimising it for printing. Some page elements may have been deliberately hidden.
