(Topic ID: 304279)
GnR Matrixed switch #35 lockup Enter (Stuck closed)
By Animal
9 months ago
  • 12 posts
  • 4 Pinsiders participating
  • Latest reply 47 days ago by matlynch91
#1 9 months ago
Received our GnR LE today (woo hoo) and upon powering it on I received an error message:
Haven't had a chance to look more closely and planning to at end of day, but Im wondering if anyone out there has had this issue. Its up at (maybe under?) the upper play field. Maybe related, the machine is not launching a ball and points start to ring up with no play.
Any ideas?
#2 9 months ago
Quoted from Animal:
Unstick #35
#3 9 months ago
not sure what #35 is? Is it under the upper play field?
#4 9 months ago
Quoted from Animal:
Says lock up enter.
Tests - Switches - Single Switch - scroll down to #35. Little box on playfield map shows the area.
#5 9 months ago
Did that, I guess it is under the upper play field since the location on the map doesn't have a switch at that location on the upper play field.
#6 9 months ago
is the "lock up enter" under/near the tip of the guitar headstock? If so, that is not the location on the playfield map?
#7 9 months ago
Quoted from Animal:
Check the wire colors. Then check under the main playfield. See if it's a switch you can remove from there to check.
#8 9 months ago
Thanks LTG, got it fixed, in the end it was in upper play field. Got it fixed, played a couple of games man I suck!!
Thanks again!
2 months later
#9 6 months ago
Quoted from Animal:
Thanks again!
Hey Animal - I’m now having this issue. Any more info on what the fix was? Thank you!
Added 183 days ago:
Edit: I fixed it but now sure how lol. Rolled a ball around in the upper playfield and flipped upper flipper a few times.
4 months later
#10 47 days ago
Quoted from Animal:
Thanks again!
I’m having this same issue. What was the fix? Thanks.
#11 47 days ago
Quoted from matlynch91:
What was the fix?
Sounds like a switch not closing on the upper playfield.
Go into Tests - Switches - Matrixed and hit switches up there. See if you find it by name on the screen or one not working.
#12 47 days ago
Quoted from LTG:
Thank you. I’ll poke around.
Go Twins!
$ 23.00
Precision Pinball prod.
$ 60.00
$ 84.95
$ 299.00
Cheap Drainz Shop
Gweem's Mods
