(Topic ID: 222096)
Gluing inserts...........what glue?
By mrbanjo
1 year ago
  • 26 posts
  • 20 Pinsiders participating
  • Latest reply 1 year ago by Ballypinball
    #1 1 year ago
    Wood glue = OK?
    #3 1 year ago
    I use wood glue. I've used it several times with no issues.
    #4 1 year ago
    What about lifting inserts in a Fire. I just want to loosen them up and re-glue, do you have to remove completely?
    #5 1 year ago
    Ask Kruzman.
    #6 1 year ago
    I know it's not officially sanctioned by Vid, but I've used straight wood glue on the inserts of my EMs. It's forgiving, wipes clean, and gives you enough time to make repositions if you screw something up. I haven't run into any issues with it yet.
    #7 1 year ago
    I use Gorilla gell glue with great success .
    #8 1 year ago
    Epoxy scares people,but it shouldn't. Only glue I would use for inserts,especially if I'm going to clear coat with 2-pak.
    #9 1 year ago
    Agree. It’s a plastic and wood joint- presumably your looking for a long term stable solution. Use what the pros rely on.
    #10 1 year ago
    I've had no problems with wood glue, and it is more forgiving than Epoxy if you make a mistake.
    Worst thing I ever did was use a type of Gorilla Glue that I didn't realize expanded as it dried, what a horrible mess!!
    #11 1 year ago
    I use wood glue, easy to use, dries slowly, positioning insert is easy, then clean up excess glue. No issues at all. If you clearcoat then that will hold your insert in as well, most likely forever.
    Just my 2 cents
    #12 1 year ago
    PVA - Poly Vinyl Acetate i.e. Wood Glue
    #13 1 year ago
    Do you have any intention of clear coating the playfield? If so do not use wood glue.
    #14 1 year ago
    Quoted from EM-PINMAN:
    I use wood glue, etc.... No issues at all. If you clearcoat then that will hold your insert in as well, most likely forever.
    Quoted from ArcadiusMaximus:
    I'm not confused now
    #15 1 year ago
    Yeah, sadly these types of questions receive all possible answers because there are a bunch of people who have done this once, a good number have done t twice, a few less three to five times and then the very few who do this multiple times a month and have been doing so for years and have to deal with customers shit when their restored playfields have inserts cracking the clear or whatever. All you can do is figure out who you want to take the advice from and seek that out.
    There is a thread on playfield restoration by Vid with thousands of posts that has additional insght, maybe read theads by HEP, or other restorers to figure it out. Certainly they could use different glues, and I would rely on any they recommend. I doubt there is a single correct answer and I suspect there are multiple slightly wrong answers that appear to succeed at first but will fail over the long run. That’s how the games were manufactured back in the day and that’s why so many inserts are needing to be fixed so I suppose anything will work for a couple years.... I prefer modern solutions and so use high quality epoxy that bonds plastic and never yellows. I think I started doing this after reading advice from someone with far more experience than I.
    One thing for sure- use some glue.
    #16 1 year ago
    E6000 is what Williams used
    #17 1 year ago
    Quoted from PinZig:
    Wood glue does just that, glues wood. To glue a plastic insert to a wood substrate an epoxy should be utilized. Lightly scuffing and or using a plastic prep pen on the side of the insert will help increase the chances of a proper bond.
    #18 1 year ago
    Ummm. Whats E6000 Wayne?
    #21 1 year ago
    I use weldbond also for mostly em pinball inserts. For new inserts epoxy for new playfields I sand down. I do not sand the edges of new inserts, & likely no other manufacturer does it. Just adds to costs, & is not needed.
    #23 1 year ago
    Quoted from phergott:
    I use wood glue.
    Quoted from mbaumle:
    Quoted from dgpinball:
    These guys seem to know whats up! I've done hundreds this way.
    No crazy or Gorilla glue for sure. Especially if you make a mistake or ever desire to remove them again. Not to mention what happens when it gets on the playfield
    #25 1 year ago
    #26 1 year ago
    We bought a little compressor and glue gun with a foot peddle to apply evenly when we made some mm playfields
    Pin Monk
    $ 9.99
    $ 125.00
    Lighting - Backbox
    Great American Pinball
    CzTV Mods
    $ 200.00
    Maple Street Sign Shop
    $ 99.99
    $ 3.00
    Doc's Pinball Shop
    Top-Notch Target Shields
    $ 275.00
    $ 154.00
    Id Rather Play Pinball
    $ 74.99
    $ 799.00
    $ 50.00
    € 8.10
    Buthamburg
    $ 11.95
    $ 54.99
    $ 99.99
    $ 11.95
    Various Novelties
    GC Pinball
