OK - since the left flippers did not move during power up, that narrows down the problem to either no voltage to the flippers or no signal from the SDB to the left flippers. Again, look closely at the wires going to the left flipper coils before going further.
With the playfield up, measure voltages on the left flipper coils - you should read about 43 volts DC between the coil leads. If no power, you will need to search for a broken wire. Using a multimeter, you do that with power off. With the meter on Ohms, touch both leads together and verify the meter reads zero or close to it. Then, hook one lead to a wire on the coil, and the other lead to the SDB, connector J1, pin 8. You should read about zero ohms - if not, try the other side of the coil - one of these should read near zero. Next is to check the other wire - connect to it, and the other lead to the rectifier board, connector A2J1 pin 6.
Report back. Others will need to chime in - we all have our own way of troubleshooting - some prefer to check with power on, but since you're "new" to this, its safer to check as much as you can with power off. In fact, its probably better for you to do the power off checks first before trying to verify power to the coils.
Let us know.
