I'm trying to debug a GI issue on Gilligan's Island. Burnt J120 and J121 IDCs have been replaced, J115 IDC has been replaced, fuses have been checked. None of these have fixed the problem so far.
Only certain GI chains (orange and yellow) work, purple, brown and green do not. Per pinwiki http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#General_Illumination_Problems , I checked the voltages between a specific GI chain and its tracer on J120 and J121 and get 6.5 VAC for orange and yellow, but only 1.5 VAC for brown, green and purple. Pinwiki only says if you have voltages using this check look elsewhere, but doesn't elaborate if the voltage isn't between 6 and 7 VAC.
My thought is next to check the voltages at J115 to see if I'm getting what I'm supposed to there. If so I can surmise the problem is between J115 and J120/J121 (i.e. triacs). I was going to check the triacs but the link in pinwiki to that procedure is dead.
My question is, what should the AC voltages be at J115? Do I check them using TP1?
