Quoted from Inferno:So, as the island spins during test (when the game is first turned on) the ramp drops and stays down until a ball comes from underneath? I'm assuming the ramp goes up and down in test right?
have you checked the switch that tells the game the ramp is in the up position? You can see it from underneath. Check the linkage also.
Everything appears fine
Is there logic that it should “know” to be up or down ?
So if it prematurely dropped it corrects itself
