I'm cleaning up and shopping my GI, and took it for a test spin. I noticed that a number of solenoids no longer fire that used to and upon inspection noticed F105 was blown.
I replaced it and turned the game back on. The game would not completely boot up and constantly reset until F105 blew again; after that the game booted up fine. I've looked at a number of other threads about similar symptoms and started checking the 8 coils and transistors associated with F105:
- all transistors check out
- coil #1 (AE-23-800) has a resistance of 0.4 ohms
- coil #2 (A-14701) has a resistance of 4.7 ohms
- coils #3, #4 (AE-26-1200) have a resistance of 10.6 ohms
- coils #5, #6 (AE-26-1500) have a resistance of 14.1 ohms
- coils #7, #8 (AE-23-800) have a resistance of 4.2 ohms
- no visible/obvious shorts
So it looks like coil 1 has an issue. But it's brand new. I just replaced it because the power lug on the previous solenoid had completed separated from the coil. Plus, it's on the topside of the playfield under layers of ramps and plastics, making replacing a b!tch.
Anything else I can test to see what the culprit is? I'd hate to replace the coil again only to have it meltdown too.
