Am finishing a restore of a G.I. The initial startup test yields an Island Error, and the motor does not move at all. In Motor Test, the island lock solenoid engages/disengages and the Lock Switch toggles from 0 to 1, but the Island Opto never changes from 0, even if I force rotate the island by hand when it is unlocked. I can tell that the microswitch for the lock mechanism is engaging properly.
I'm thinking the opto board is not getting the proper voltage from the driver board, or is not working correctly. I can see from the schematics and opto board diagram that J118 should supply GND and +12v dc. When I measure at the opto board 4 pin molex connector between grey-yellow (+12vdc) and black, I get a low voltage reading on my meter, around +5vdc.
When I unplug J118 from driver board, and test the voltage across pins 2 and 3, I get around 8-9 vdc, well under what I think it should be. Same with TP1.
The green island plastic does not sit in the middle of the opto sensor, it is almost flush against one side of the sensor. Does it need to be lined up in the middle? I've read that it could be reading through the plastic, so I took a black sharpie and filled in the outer edge of the black plastic where the sensor would go by, but no change. The motor did click on twice randomly on a power up, but never in test mode.
My motor is brand new, the relay board is a repro from Great Lakes Modular, but I've tried also with the original Relay pcb.
I've read that you can ground Q58 to activate the relay and get the motor running manually. How does one do that exactly? What pin on Q58 do I ground?
Thanks for any help.
