I’m trying to get a Gigi to light a (any) match lamp consistently at game over. Right now that’s only happening about two thirds of the time. The other third of the time the switch contacts on the 0-9 stepper aren’t lining up, and therefore no match lamp is lighting.
I’ve made what I think are the usual adjustments, including:
• Removing, cleaning, and adjusted the positioning of the coil
• Checked the various spring tensions
• Checked the bracket that limits the movement of the coil plunger into the coil
• Checked the bracket that limits the travel of the arm that rings the bell
When manually activating the coil, I noticed that the arm that “pushes” the gear up and advances the stepper wasn’t always pulling in far enough to push under and up on a gear tooth. So I was pretty sure adjusting that spring tension tighter, so that the arm always retracted under a gear tooth, would fix the problem. Wrong! The stepper is still occasionally missing a contact.
Any suggestions for the likely cause or other adjustments I can make?
Thanks in advance!
