New! Dark mode!
(Topic ID: 67669)
GI Wire for lights - product source? - [Update source found cheap cheap]
By Spudgunman
7 years ago
  • 19 posts
  • 8 Pinsiders participating
  • Latest reply 6 years ago by Spudgunman
    #1 7 years ago
    I remember reading on here once a good source of GI wire (staple wire on the bottom side of the playfield)
    what are good places to source this? part numbers?
    update:
    amazon.com link »
    takes a solder and its dead nuts on to two units I compared against OEM
    #2 7 years ago
    I find the best deals on it on ebay (lots of companies buy big spools and sell off the excess as surplus)
    ebay.com link » Free Shipping 25 Flat Braided Copper Wire Ground Strap And Shielding 1 4
    #3 7 years ago
    Try pinrestore.com. They sell both the tinned bare wire used for GI and 1/4" ground braid.
    http://www.pinrestore.com/Supplies.html
    #4 7 years ago
    yea I was hoping for a non pinball reseller.. is this used anywhere else.. 75c a foot is sort of silly.
    #5 7 years ago
    Amazon has some, try this link.
    amazon.com link »
    #6 7 years ago
    Quoted from Spudgunman:
    I certainly share this sentiment. I recently had a couple PF swaps in the hopper and looked extensively for bare stranded tinned copper wire and couldn't find anything for sale online or locally in reasonable quantities. There are a number of online retailers that offer small spools solid core tinned bus wire (which will certainly work fine for GI) but I want my games to look as original as possible. For me, it was worth paying a little more to get the Pinrestore wire knowing it would look closer to the stuff used in the factory.
    Let us know if you find any other options.
    #7 7 years ago
    a local reseller vetco had a bunch but just checked today and they are out.
    #8 7 years ago
    Quoted from toyotaboy:
    I find the best deals on it on ebay (lots of companies buy big spools and sell off the excess as surplus)Ebay link
    Quoted from Out-West:
    Amazon has some, try this link.amazon.com link »
    He's looking for lamp braid, which is surprisingly a lot harder to find unless you want to buy 1000' spools. Action Pinball sells it for about 25 cents a foot if you don't mind it being a larger gauge than original (16 ga). As mentioned previously, Pinrestore carries the "correct" gauge (debatable) wire and is the only other place I've found to buy it in realistic quantities.
    #9 7 years ago
    Even the Pinrestore wire is a little beefier (18 awg, IIRC) than the stuff I pulled off the early SS PFs I'm swapping. It is however very sturdy, easy to work with, and looks great.
    #10 6 years ago
    I found the perfect source its for hanging pictures anchor wire. frame shop had it 100' for 20 bucks.. that will set me for life.
    its the exact stuff on two playfields I saw..and hell of a lot more reasonable prices then any pinstore. (likely its what they are using)
    I saw some in ACE hardware as well in the screw isle.
    amazon.com link »
    #11 6 years ago
    As long as it takes solder, that is excellent!
    #12 6 years ago
    What is that picture hanger wire made of? Is it really the same material used for ground braid for the lamp sockets on pins?
    #13 6 years ago
    Well I can tell you its not galvinized and looks the exact same wire.
    I can also tell you that there is no such thing as "pinball wire" they just buy what works
    I refuse to pay $1 - .75 a foot for wire that is common hardware store part.
    Vid yes it took fine wire solder with flux core (didn't add extra flux and it took)
    #14 6 years ago
    Photo attached for your pleasure
    image.jpg 2 MB
    I'm laughing out loud because I used the same thing for a repair. The stuff works like a champ.
    If you don't need a great deal of wire, any lighting show-room in your city should have that wire in stock. They could probably order a spool for you if you need a lot.
    #15 6 years ago
    also just found out wallmart sells the same stuff for $2 for 25ft
    #16 6 years ago
    You may have some voltage drop problems as this is a metal wire not tinned copper wire.
    #17 6 years ago
    you are kidding, right?
    #18 6 years ago
    Nope, steel resistance is about six times that of copper.
    #19 6 years ago
    well to get detailed this fancy tin coating is about 10x and steel is about 13-16x that of pure copper so ignore any skin effect and solder resistance. but that is getting into weeds.
    sure not debating the point you raised from science ... but the statement that "it matters" in voltage drop in application here..
    to be clear..yes to state a clear fact you are correct mathematically and in terms of physics..
    AND to further just show that I am not insane.. with my home 'spectroscope' testing OEM wire shows copper in the wire where this "cheap" stuff is well just iron looking core.
    but to suggest that it gives one hoot of a difference in practical application we speak of here ..is a waste of cash. (and laughable IMO)
    the standard pinball Gi track is no longer then 4ft. there happens to be (with my test gear) .7ohm resistance on 4ft of "fancy" vs "cheap" so we are at a wash there.. (I had a win to the new wire at .5ohm likely because its not oxidized and this was far from an official test - just holding a probe tip ..mind you this isnt copper core probe tip either .. I didnt upgrade to 'monster' silver plated probe tips yet)
    now that GI AC 6v and with mathematical voltage drop of less then 3%.. even if that mattered for most pinball GI that is typically incandescent which wouldn't matter on voltage in the first place! (for the roughly .2v loss) as the lamp will light with proper amperage under most any case (lets say 1v, but delivering 6A at 1volt is problematic for other reasons) lets pretend its LED's (where voltage is more important) then we have less amps and the voltage suffers less so again.. waste of cash. (IMO)
    not even delving into the topic that the connection from the lamp base to the lamp, and the lamp in the base is just friction contact! (except for 555 which only has one friction contact)
    that is why I wondered if your joking.. sure for a college classroom your correct but practical application is insanity. (IMO)
    So .75c a foot or .005c a foot, your money your game your choice. the orginal post here was looking for budget GI wire.. people who choose to pay high prices for wire.. why look here? just pay your price and look down on us who did it cheaper.
    AND as mentioned going to a lamp store will find you "lamp grounding wire" they have spools of it.. however it wasn't the same size (and its not tinned) and cost a little more.. so you can have pure copper gold under your playfield. hell get a solder bath and tin it yourself!
    Playfield - Plastics
    Ramp-O-Matic
    $ 5.00
    $ 65.00
    Texas Pinball
    $ 14.00
    $ 42.00
    $ 4.49
    PinWorlds
    $ 54.99
    $ 54.99
    $ 69.99
    $ 89.99
    $ 259.99
    $ 32.00
    $ 839.00
    $ 19.99
    Bent Mods
    $ 76.95
    $ 18.95
    $ 14.00
    CzTV Mods
    $ 40.00
    Funhouse Custom Lamp Out of stock
    Professor Pinball
    $ 22.00
    $ 27.25
    The MOD Couple
    $ 19.99
    Docquest Pinball Mods
