New! Dark mode!
(Topic ID: 279309)
G.I. lights only
By Kickout
8 days ago
  • 10 posts
  • 6 Pinsiders participating
  • Latest reply 2 days ago by weeze
#1 8 days ago
Pulling my hair out. Williams Dealers Choice. Have lights nothing else.
Plug pin in
Turn on under cabinet switch
Hit left flipper G.I. and back lights come on
Drop a coin in
Game over light goes off
Scores reset
Ball ejects into lane
FROM THERE NOTHING
No flippers
No pop bumpers
No rollover switches
Nothing
HELP
#2 8 days ago
Should have added.
Fuses all checked and correct
Tried jumping some Playfield coils and nothing.
#3 8 days ago
I would check tilt switches
#4 8 days ago
If you look thru the relays in the manual - available here: https://www.ipdb.org/files/649/Williams_Dealer_s_Choice_manual.pdf - you'll see that some 'open circuits to playfield switches,' so check those. Also could be Jones plugs or the bridge rectifier (or its fuse).
#5 8 days ago
Check these 3 switches on the Game Over, Reset, and Tilt relays.
#6 8 days ago
Yup , check the game over and reset coil switch stack . Just had this exact issue on a Captain fantastic . Game would start normal but only the gi lights would work . Turned out a little hunk on one of the game over switch stacks . Clean up and manual triggered a few times and game came back to normal . Not saying that’s the issue but worth a shot
#7 7 days ago
Ok, now have the game starting with the following Problems
Ball will not eject to shooter lane
Manually install 1st ball game places and scores correctly
Ball drains and does not eject or move to ball 2.
Kickout
#8 7 days ago
Quoted from Kickout:
What did you do?
Check score motor sw. 4D. The action of the ball moving across to the shooter lane will advance the ball count.
#9 6 days ago
Re-cleaned and Re- checked all the Game Over switched and the game is now operating.
Thanks to everyone for their help
Kickout
#10 2 days ago
Have this same problem on a 60s Gottlieb. All GI works, ball serves up, score reels seem find BUT the bottom half of the playfield all coils dead.
Checked fuses and fuse holders.
Checked out the plugs extensively.
seems like Ive been through the game several times at least up to the point of feeling like the fuses, tilts, and plugs are not involved but is it possible Ive missed a tilt? If I did wouldn't all coils be quiet on the playfield?
Resistor and/or Bridge Rectifier bad?
Actually I forgot if its a resistor or a bridge Rectifier but I do have the top half of Playfield and head coils working.
oh and its a Hurdy Gurdy
Thanks in advance
$ 66.95
$ 66.95
$ 245.95
Allteksystems
$ 4.49
$ 19.50
Apparel - Unisex
ArcadeMade
$ 229.99
$ 11.00
Tools
Troxel Repair
Filament Printing
$ 999.00
$ 54.99
Flashinstinct
$ 149.00
Sparky Pinball
Mods for your pinballs
$ 175.00
Professor Pinball
$ 27.99
$ 69.95
pinballmod
$ 18.00
The MOD Couple
$ 96.95
$ 89.95
$ 249.00
Tilttopper
$ 239.99
Tilttopper
