(Topic ID: 178630)
GI lights blew out while installing LEDs on Genesis
By bpa
7 years ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by bpa
#1 7 years ago
I bought a bunch of Comet single led flat tops for my Genesis. I was replacing the GI and some other bulbs while the machine was on but from the top side. Everything looked fine and then my GI went out. I checked the fuse...it's fine. I thought about switching all the bulbs back to incandescent in hopes of maybe finding the culprit. What would be the best way to narrow down the problem?
#2 7 years ago
When you "checked the fuse" did you actually go through the fuses with the multimeter, and not just do a visual inspection?
If I remember right, the GI is controlled by a relay.
Does the game still boot normally? Can you go through the solenoid and lamp tests?
#3 7 years ago
You probably just shorted something while changing bulbs, if you have the right sized fuzes in place you should be ok, i did it once and now just turn machine off so you dont have an accident.
#4 7 years ago
It was a fuse. Duh. I thought I pulled it out to check continuity but apparently not. I do have a few controlled lamps that are not working like LEGS ARMS etc. so I need to figure that out now.
#5 7 years ago
Everybody learns this lesson--don't change bulbs with the power on.
#6 7 years ago
Quoted from ForceFlow:
Wait until you learn the lesson don't change a fuse with the power on. Oh boy.
#7 7 years ago
Quoted from Taxman:
Yikes, I don't think I've seen anyone try that yet
#8 7 years ago
Ok so I am having a strange issue with the body part lights. They were originally working fine but now I have one or two out of each part. If I swap the led out with a incandescent bulb and turn the back on, the incandescent works in attract mode a couple of times and then stops working just like the led. The bulb does not blow out though. I tested it and it still works. Any ideas?
$ 83.00
PinballReplacementParts
2,500 (Firm)
Towson, MD
This page was printed from https://pinside.com/pinball/forum/topic/gi-lights-blew-out-while-installing-leds-on-genesis and we tried optimising it for printing. Some page elements may have been deliberately hidden.
