Working on a NGG and having issues with the GI. Only one side of the playfield lights up. The other side doesn't. I measured the voltage at the pins J105 and J106 a couple different ways and got the same results on both. First method: Ground black lead of DMM to ground test point, red lead touching each pin. From right to left I don't receive any reading on the two pins with the red line. The other pins I get 7.6 volts DC. Second method: Touch black lead to first (right side) pin, then red to pins 6-10 and get 7.6 at each pin. Same is true for the other four pins on the right???!?!?! I thought maybe it was the molex connector so I snipped the wires for the GI section not working and touched them to their respective pin. No luck. However, I touch them to the pins for the working GI section and the lights work. So I know it is not a wiring issue but a board issue. I just don't understand why when I touch my black DMM lead on those two pins not working and touch the other pins on the left I get a reading? I guess I can pull off the board and check for a cracked solder joint. Any help?
