My buddy just dropped off a pin to be shopped out. The first thing i notice is that half the GI is out. Yep, j6 is toasty. Do you think this is repairable or is it time for a new board?
Yep, no problem repairing.
Make sure you replace the female connector too, even if it somehow looks good.
Quoted from doublezo1:Should i throw some solder on it? The original solder is burnt off and doesnt go around the pin hole like the others do.
Is there a trace on that side of the board, or just a pad?
Quoted from doublezo1:Female connector is also wasted.....
I kinda figured that would be the case, lol.
Vid1900. The trace ends where you see it on top of the screwdriver blade. There is nothing on the oppisite side. I can only get a buzz from my MM when i touch the piece sticking up so basically a pin will not touch the trace when its in the hole..... im entering uncharted territory with my board repair skills.
You can re-make the connection with a wire on the backside of the board.
This will look cleaner and give you something solid to solder to.
Use a thick piece of wire, there is a lot of current running though those traces.
Ok... looks like ill need to do my first jumper wire. Any helpful tips would be great. Or pics of said repair would be awsome! Thanks!
Ok... 18-20 guage wire. Circled in red are the connections that buzz with the MM. Im thinking of running the jumper wire as shown. Does this look like a good place to do the jump? Ive cracked open a few pops so it will have to wait until sunday afternoon, just plannin ahead i guess..
I can't see where the trace goes to, but use the shortest most direct route. the key is restoring the circuit that was damaged, as long as it's restored it does not matter which point you connected it.
Sweet success!!! All gi works. Thanks for the help, im going to need some more. Im having another issue. When i start up the pin it doesnt boot. It makes the all good tone then does nothing. I press the advance button and get it into diagnose mode then it acts normal, plays etc. Turn it off and the same thing happens again. Hopefully i make sense.Thoughts???
Yes there are credits. Its weird. Its almost like it starts in diagnose mode when turned on. It doesnt go into attract mode until i press the advance buttons on the coin door and get it out of the diagnose mode. Then it starts attract mode , acts normal, plays games etc... strange.
Quoted from doublezo1:Yes there are credits. Its weird. Its almost like it starts in diagnose mode when turned on. It doesnt go into attract mode until i press the advance buttons on the coin door and get it out of the diagnose mode. Then it starts attract mode , acts normal, plays games etc... strange.
Might want to check the batteries for corrosion. My es did something similar. Dead battery corrosion ended up being the issue.
This page was printed from https://pinside.com/pinball/forum/topic/gi-connector-is-crispy and we tried optimising it for printing. Some page elements may have been deliberately hidden.
