Hello Guys,
i have some bugs I haven't found on the list.
All of those Bugs are related to my GB Pro running(of course) 1.13code
-Multiball Ballsave
While in Multiball, shoots in the Subway(right saucer) triggers ballsave but it shouldn't(Shoot-Again starts flashing). Center drains won't be saved(like it should be) but outlane drains will serve a new ball. This bug does occur in every Multiball. I guess(Feature Adjustment #14) "Subway Ball Save Time" should only be available during Mainplay and scenes.
-Captive Ball Bank
Sometime the reset timer is not held properly. For instance while starting Storage Facility Multiball you can hear the the timer running out "beep" and all the balls will be rejected. This does also happen in the Extra-Ball animation, starting Scenes and some more animations.
-Stupid Slimer
Slimer sometimes does stupid things. This might be on purpose but im not sure. If I have Slimer mode going on in order to light scenes. He is normaly jumping up and down slightly(on the Pro) like he should be. But sometimes he moves a bit up(to the middle or upper position) and keeps jumping there for a short amount of time. The ball can't hit him in this position. I haven't found a way to recreate it. I checked the switches, they are working fine... My original Playfield and my new(non-ghosting) Playfield both had the same issue, so it must be related to the Software.
-Left Kicker
If Scenes and Tobins Spirit Guide are lit at the same time. Sometimes the Scene starts before TSG is awarded. The Scene music starts for 2-3 seconds before finally starting TSG after collecting the awards scene music starts again. Shouldn't TSG have priority above Scenes?
-Grace Period
There are actually a few bugs related to grace period fails. For instance, if a mode timed out without completing it and draining the ball while in grace period. The scene is not awarded correctly. Sometimes you'll have to re lite scenes in order to play it again.(Out timed scenes should be awarded, even if not 100% finished)
Another instance if "Back of Man!" or "Stay Puft Marshmallow Man" timed out without completing it and shooting the ball up the main ramp while in grace period(just before Mode total and WKWS is lite message is displayed) both WKWS and one of the Scenes of the Ramp(We Got One, He Slimed me, The Ballroom) start at the same time. However this won't happen all the time. I guess it does only occur if you would be able to start another scene without doing Slimer first.
Thats all for now. Again Ghostbusters Pro 1.13...
Greetings from Germany
Max
