I have a Ghostbusters premium.
Purchased brand new in 2016ish and it has worked great until earlier this year when it developed a ball trough issue. It would autoload balls and then could not locate the balls.
I contacted the distributor where I purchased and they walked me through a bunch of things (like 10 weeks worth of things). They sent out and I replace the ball trough sensors (both sides the sender and the receiver). No joy. We then replaced numerous boards (nodes?) like 8C and others. After the last board swap it worked!
About 2 weeks after everything was back to normal, it is on the brink again. =(
I'm attempting to fix it myself and learn a little along the way. I am teachable and pretty handy.
Currently, it looks as if the lights are "shorted". Everything flickers and lights are on that should not be on The P-K-E lights are all out too. I am thinking no way could all 3 go out at once? Related to flickering? Not sure?
There was a switch #22 lane switch tech error message, but after a few days, it no longer appears.
Video attached to visual to see what it is doing.
Any insight tips would be very much appreciated!
