(Topic ID: 170268)
Ghostbusters new ball/ Glo ball question.
By Magicchiz
2 years ago
  • 22 posts
  • 12 Pinsiders participating
  • Latest reply 2 years ago by Schwaggs
There have been 8 images uploaded to this topic. (View topic image gallery).
#1 2 years ago
Ok so looking it appears that the captive ball on the GB is not a normal Newton ball. So I am assuming I can put the glow balls in there. Anyone done this and is there any loss of momentum with the covered glo-balls instead of a normal pinball?
Magicchiz
#2 2 years ago
Sorry topic should have said Newton Ball. Or captive ball
Magicchiz
#3 2 years ago
Nope glo balls look great and don't inhibit function at all.
#4 2 years ago
Quoted from perryd:
Yup I have them too, no issues and they look great!
#5 2 years ago
Good enough, wow so easy to change. You can tell I am used to bally williams and newton balls. Didnt think I could chage them. My first new in box pin, and 2nd stern.
Magicchiz
They look great.
#6 2 years ago
I was thinking of doing this too. Would love to see a picture to see how they look.
#7 2 years ago
Here is the only photo I have that shows the captive balls somewhat.
We used 3 green on the left and one pink on the right.
Edit..
Found the photo's we did with the Mezels at Texas Pinball Festival back in March.
#9 2 years ago
Ok so I need to go get some pictures but I changed out the front ball from silver to glo green and pink. Looks really good. That was what I was talking about in the original post. Weather to leave the front ones regular silver or change them.
I will try to get some pictures tomorrow.
Magicchiz
#10 2 years ago
I have seen this as well and it looks great I did not have enough of either globals to do this but plan on buying a couple more
#11 2 years ago
where do you buy those balls ?
#12 2 years ago
Quoted from pinballjm:
Mezel mods
#13 2 years ago
This was talked about in the main GB owners thread. I think people are getting a little mixed up here about what you actually asked. The general consensus in that thread, was that actually replacing the front captive ball does cause problems. You will lose momentum and it will make it harder to push the balls into their target if your front ball is a glo ball. I tried this on mine as well, and came to the same conclusion. Luckily, they were easy enough to swap back the standard pinball into the front of each captive section.
#14 2 years ago
Yes.....I too, needed to leave the Metal front ball for Energy transfer.
The Glo balls, appear to fly over a bit easier, and I have noticed I dont get the "streak"
in the middle of the clear plastic cover as easily, as I do with metal.....OCD...drives me a little crazy!
#15 2 years ago
Still trying to figure out if that is true.
Magicchiz
#16 2 years ago
I am also trying out a few things on the rails just to see if there is much difference. Or just another nudge chance before a side drain.
One is hard to see. I only had black post rubbers to cut one up. So it would be to just cut and place a post rubber over the larger of the out rail. With nothing on the inside smaller rail. The second is the glow titans on both. Seem to work well and even with it split at back they have not popped off yet.
#17 2 years ago
Quoted from Magicchiz:
Magicchiz
Any luck using glo-balls in the newton cage? I was thinking about doing this too, but figured I'd ask before buying them.
#18 2 years ago
Well I have taken out the regular balls and replaced with balls in the cage with glo balls. With a direct hit I am not seeing a big difference. Although I may put the regular ones back in and see if I get any easier shots or glancing shots on the regular ones better. The glo balls sure do look better. I have no issues with the librarian captive ball and glo. It is interesting that I had replaced my Rays Ball busters to blue glo balls in my BBB. I find there is just a little drag to them. I think it is because of the coating. I think it might be the same with the green ones due to having to go up and around the loop and having to transfer momentum thru 3 balls.
I say try Glo. but each to their own.
Magicchiz
Boy is it a tough shot those green ones.
JC
#19 2 years ago
One more quick question. Are the green glo-balls the "Monster Green" or "Lightning Yellow"?
#20 2 years ago
Quoted from jrockne:
They are the Monster Green.
3 months later
#21 2 years ago
Has anybody used the "Glow in the dark" green Glow-balls instead of the fluorescent green Glow-balls? If so, how do they look, do they really glow in the dark?
#22 2 years ago
I have the glow balls in the front position and notice zero difference in energy transfer. Could it be that the people that have an issue are clamping the front ball down too tight? I left mine a little looser, with some effort, you can turn the ball in the mount.
Also, it looks WAAAAAY cooler to have the front ball colored!
Meph's Mods
7,500
Brighton, MI
$ 28.00
Pin Monk
$ 69.99
