so the last time I shopped my GB pro I tried to adjust my slimer mech because it was not registering hits well. When re-assembled, the problem just got worse, and I found out that the 'old' style slimer mechs are faulty and have been replaced on the line with a new model.
Unfortunately I was already a year over my warranty and so my only option was to buy a NEW slimer mech, quoted at $250....
So I thought I might as well try to fix it myself on the cheap before dropping that much cash. The problem, is that the 2 plastic pieces that hold the 'ball' above slimer did not allow the cable to swing enough to touch the rims of the circuit board. so I removed the two plastic pieces, and cut my own replacement spacers, using the top plastic layer as a template. I scanned the top protective plastic piece, and drew the same shape, with a wider negative space inside to allow the cable to swing around more inside. Then I cut x3 (1/8") spacer shapes with my laser cutter and put the thing all back together. Now slimers cable hangs right where it should, and is free to move when hit.
for anyone with an old slimer who does not want to drop $250 on a new one, this is a viable option. His plastic ball is now hanging down, I could cut it off at this point but It doesn't really bother me.
Glad he's back in action, the game is a lot harder when he's disabled.
