(Topic ID: 158155)
Ghostbusters Club - We Got One!!!
By 30FathomDave
8 years ago
  • 12,619 posts
  • 918 Pinsiders participating
  • Latest reply 38 hours ago by Rager170
  • Topic is favorited by 342 Pinsiders
There are 12,619 posts in this topic. You are on page 226 of 253.
#11251 1 year ago
I need to replace some of the LEDs because they need it.
Quoted from SKWilson:
What kind of LED light kit? Like you would use to replace incandescent bulbs in older games? If that's the case, you should know that GB is already LED.
#11252 1 year ago
**Update**
I think this may be "mod" related - I Recently installed the Ghostbuster's Mini TV and Ecto 1 car (Mezel Mods)- seems if I disconnect the TV MOD - it doesn't do this - although very rarely the lights flicker...I'm wondering if I need to attempt an alternative power wiring? Anyone run into this before?
Hey folks - anyone know why the start and coin lights may be doing this?
#11253 1 year ago
I have a few things available for the Black Friday sale including the Proton Gun Mod priced down
$700 AUD is roughly $460 USD to give you a rough idea
Black Friday Sale Brochure (resized).pngBlack Friday Sale Brochure (resized).png
#11254 1 year ago
Just joined the club. Picked up a premium a few days ago! Game rocks. . Only thing that drives me insane is the ball will stay in the pops forever. Specifically the top left one. It will bounce in a triangle pattern for ever. Happens constantly. Is there a fix for that?
#11255 1 year ago
Quoted from vintage4life:
Mine does this, too. All the time. I am thinking that maybe I could plant a skinny post behind that rubber and push it out a bit, but I am not at the point I want to drill a hole on my play field---even though it would be hidden.
#11256 1 year ago
Try changing the angle a bit!
#11257 1 year ago
Quoted from cottonm4:
Maybe adjust the leaf switches a bit so they aren’t quite as sensitive?
#11258 1 year ago
Mine stays in the pops for a long time also. My friends does not. You can also backhand the right orbit shot to start a mode on his. On mine, you can't. Guess it's a slope thing?
#11259 1 year ago
Quoted from gliebig:
Adjusting the flipper angle opened up a ton of shot opportunities on my premium.
#11260 1 year ago
Quoted from oradke:
I tried a bunch of angles. Still does it. Pretty sure I could have the pin upside down and it would still do it. I’m about to disconnect that pop.
#11261 1 year ago
I have the same problem with those pops, sounds like it's pretty common. I have a solution and started tinkering, but haven't proven it yet.
It consists of a delay circuit that is triggered by the first pop. When it times out, all of the pops are disabled (power cut off to them). It could time out for maybe 20 seconds, then disable and drop the ball, then reset after a few seconds to its standby mode.
It'd be a simple design and then just a matter of implementing it into the machine and testing the design.
If there's enough interest out there, I'd move forward with it.
#11262 1 year ago
Quoted from Spelunk71:
There are not any leaf switches. The ball gets locked into bouncing back and forth with the rubber just to the left on the little yellow car on the racetrack and the rubber ring on the right hand side of the racetrack.
Quoted from oradke:
Should I make the angle steeper or less steep. I have the bubble sitting in the middle on the two lines on the spirit gauge.
Quoted from ramegoom:
I'm thinking I will try something in a couple of days. Something simple. I m going to try splitting a soda straw lengthwise and slipping it over that rubber ring. It if it works it will be a very cheap fix. If it does not work, not much time and no material expended.
#11263 1 year ago
Ok I think I fixed it for now. I just moved the rubber down lower on the post. Played a few games and it’s awesome so far.
7B541049-271C-483E-AF8D-4FBC4546E20D (resized).jpeg7B541049-271C-483E-AF8D-4FBC4546E20D (resized).jpeg
#11264 1 year ago
Finally got a Ghostbusters back in the house after years of trying. A Pro this time, had a Premium originally at release. Now for some simple mods: Containment Unit, Firehouse, Library, and some symmetrically stacked books to add something in the middle.
Had the Walter Peck figure in storage for years waiting for this.
PXL_20221123_213632770 (resized).jpgPXL_20221123_213632770 (resized).jpgPXL_20221124_015855816 (resized).jpgPXL_20221124_015855816 (resized).jpgPXL_20221124_021212074 (resized).jpgPXL_20221124_021212074 (resized).jpg
#11265 1 year ago
You da man, man ! I moved the rubber down as you suggested. The difference in game play up in the pops is much better.
So, when it comes time to replace the rubber. that post needs to be turned upside down.
Thank you
#11266 1 year ago
Quoted from CoasterG:
That’s awesome! Walter Peck comes with a brick wall complete with containment system door? Nice. You can get stacked book mods in a few versions, but I liked the one that came with the librarian ghost I bought.
D3FDBFC2-0369-495F-BD1C-6D897B426B4A (resized).pngD3FDBFC2-0369-495F-BD1C-6D897B426B4A (resized).png
#11267 1 year ago
Quoted from Pinkitten:
That really is symmetrical book stacking. Where's it from?
Are there schematics available? The auto plunger isn't working properly and I'm betting I'll need parts.
#11268 1 year ago
Not sure about schematics, but the librarian ghost and book stack is available for around $40 from a few vendors online. Just google it and these should pop up.
BC9AA262-5E24-4224-8E6C-7BED24FC4FA9 (resized).pngBC9AA262-5E24-4224-8E6C-7BED24FC4FA9 (resized).png
#11269 1 year ago
Not sure if this is what you are looking for but page 35 shows the ball launch assembly.
https://sternpinball.com/wp-content/uploads/2018/10/Ghostbusters_Pro_web.pdf
#11270 1 year ago
Thanks, ended up finding that last night. Love how it's labeled no schematics and it has most, if not all of them.
#11271 1 year ago
Congrats!!
Can't wait to see the mods
#11272 1 year ago
I'm not sure I understand. The only schematics would be for the circuit board in the backbox---and I don't know what Stern's policy is if you need that CB repaired.
As far as the auto launch assembly, to me it looks like all the parts are pictured and identified with part numbers.
What am I missing?
#11273 1 year ago
I made this one for myself - looks so good in the game. Way better than the original! I believe I have pics earlier in the thread. I’m going to look into that stack of books though, haven’t seen that one!
#11274 1 year ago
Went thru my Pro this morning. Got most everything adjusted and repaired, working on cleaning off the 6 years of protective dirt on the playfield.
How good is the Mezel Mods firehouse? It's the only one readily available and the photos they have in the site aren't so great compared to the install photos I've seen.
#11275 1 year ago
The Mezel is way better than stock just not the killer fire house one that are so hard to get.
#11276 1 year ago
Anyone see the colored captured balls available anywhere? The green with blue or red sets. Mezel doesn't have them currently.
#11277 1 year ago
Mezel Mods firehouse is still a great mod, the red metal building looks out of place. Get it and be done, I have Mezel Mods firehouse and will never take it off unless I can get one from wolffcub
#11278 1 year ago
Quoted from camcamaro1991:
I had the Mezel firehouse until I upgraded to wolfclubs awesome Firhouse. Next best option.
#11279 1 year ago
Wolffcub’s firehouse is spectacular. I hope he offers more of them. Along with Vimtoman’s Halloween house, this is easily one of the best mods I’ve ever seen. His attention to detail is bonkers, from the mini Star Gazer pinball to the flashers in the roof, it’s really awesome. I do like the Mezel mod firehouse too, it’s another great option.
4BFBBE97-ECAB-4CD0-BE8D-6EB3FE0806FC (resized).jpeg4BFBBE97-ECAB-4CD0-BE8D-6EB3FE0806FC (resized).jpegE5048923-D5BF-40C5-A96A-FB27C84D41BB (resized).jpegE5048923-D5BF-40C5-A96A-FB27C84D41BB (resized).jpeg
#11280 1 year ago
That firehouse mod looks awesome! Quick question. Can someone explain the facility multiball. What’s the objective? Just capture ghosts. How do you light super jackpot or progress through it?
#11281 1 year ago
I requested a fire house from Wolfcub. I hope he is still making them.
#11283 1 year ago
Quoted from Nstone4425:
I have a bunch of green and pink ones.
Are you willing to part with 3 green and 1 pink?
#11284 1 year ago
Ditto. 3&1?
#11285 1 year ago
I've had the game for 4 years and I can't tell you, so I'd also be interested to know if there's any structure to it.
Saying that it's so frantic there's absolutely no way I'd be able to stop and think about what to shoot for anyway during that multiball (or any of them on GB).
#11286 1 year ago
So I found a Funko Pop Firehouse in my collection. It's so close to fitting.
It's hollow. The spinner cut out would be almost perfect with the center of the doors.
PXL_20221128_235038529 (resized).jpgPXL_20221128_235038529 (resized).jpgPXL_20221128_235126339 (resized).jpgPXL_20221128_235126339 (resized).jpg
#11287 1 year ago
I also have this Pop firehouse and it's so close to Wolffcub's that I was wondering if he took inspiration from it.
#11288 1 year ago
Quoted from javagrind888:
Absolutely not. Mine is 100% my idea and I used the original movie images for the elements I incorporated. Anything can fit with enough jack and slash so the pop one might work.
#11289 1 year ago
Seems to be about an 1" too tall, going to test fit it when I remove the firehouse plastic later this week. Just looking at alternatives.
wolffcub Love your mod, I PMd you about being put on the backup to the backup list for it and about your Trap mod for the Pro as well.
#11290 1 year ago
I’m fairly close to starting the backup list.
#11292 1 year ago
I might be in on another run of the firehouse.
#11293 1 year ago
Quoted from wolffcub:
I also sent you a PM yesterday. I am still a buyer when you get more made.
#11294 1 year ago
Anyone who buys it won't regret it. It looks amazing in my game.
#11295 1 year ago
Which air ball protectors are good? Do you need sets for the outlanes and for the left ramp? I'd like plain clear ones, not tinted and don't really want the center post.
#11296 1 year ago
https://pinside.com/pinball/forum/topic/sale-ghostbusters-airball-ampamp-right-orbit-protectors-1
#11297 1 year ago
This 3d building mod looks awesome! Pics don’t do it justice. Pick one up in the marketplace. They are a great price.
49325D13-D7C4-419C-85BE-9AF790A47FBB (resized).jpeg49325D13-D7C4-419C-85BE-9AF790A47FBB (resized).jpeg5E0F9E3E-8B8E-46E3-8CBF-68CE10AE413A (resized).jpeg5E0F9E3E-8B8E-46E3-8CBF-68CE10AE413A (resized).jpegD1B8A03B-D2A1-41F3-994C-18FF84AE437A (resized).jpegD1B8A03B-D2A1-41F3-994C-18FF84AE437A (resized).jpeg
#11298 1 year ago
Anyone have link for the subway car ? Appreciate it
#11300 1 year ago
Quoted from wcbrandes:
Get this one from Amazon for $12.00, cut the ends of the car out and add your own LEDs. Don't like the graphics? Get a can of silver paint for $5.00.
https://www.amazon.com/Metro-Subway-Latino-Graffiti-Diecast/dp/B077DDH392/ref=sr_1_11
Here is the Amazon unit for $12.00.
Screen Shot 2022-12-04 at 3.48.39 PM (resized).jpgScreen Shot 2022-12-04 at 3.48.39 PM (resized).jpg
And the other one.
Screen Shot 2022-12-04 at 3.47.22 PM (resized).jpgScreen Shot 2022-12-04 at 3.47.22 PM (resized).jpg
$ 45.00
arcade-cabinets.com
$ 96.00
ArcadeMade
$ 69.99
€ 99.00
Lighting - Under Cabinet
Watssapen shop
$ 63.99
Cento Creations
$ 75.00
arcade-cabinets.com
$ 69.99
Greenville, SC
Pinhead mods
$ 55.00
arcade-cabinets.com
$ 69.99
Las Vegas, NV
$ 98.00
ArcadeMade
17,000 (Firm)
Carmel Hamlet, NY
$ 39.95
Playfield - Plastics
Hookedonpinball.com
$ 26.00
Pin Monk
$ 969.00
Mödley Crüe
$ 218.00
Lighting - Backbox
$ 69.99
$ 24.00
Pin Monk
$ 49.95
12,000 (Firm)
Eagle, ID
$ 103.00
This page was printed from https://pinside.com/pinball/forum/topic/ghostbusters-club-we-got-one/page/226 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
