New! Dark mode!
(Topic ID: 158155)
Ghostbusters Club - We Got One!!!
By 30FathomDave
  • 8,698 posts
  • 707 Pinsiders participating
  • Latest reply 35 minutes ago by yzfguy
  • Topic is favorited by 262 Pinsiders
There have been 1,620 images uploaded to this topic. (View topic image gallery).
There are 8698 posts in this topic. You are on page 124 of 174.
#6151 1 year ago
Quoted from WannabeWizard:
Just traded for a GB Pro. All stock. Should I invest in a color DMD and a shaker? What other mods do people suggest? LCD DMD or LED DMD? Any suggestions will help on mods to enjoy the experience. Thanks
Yes color DMD LED (much easier fit)!
Yes shaker motor (works really nice in this game)! It gives you a very ominous rumble when you start multi ball.
Also, swinks target brackets to massively reduce air balls.
Some kind of outlane jump guards are nice too.
Best mod tho (and free) is the movie soundtrack rom.
Welcome to the Ghostbusters!
#6152 1 year ago
Mod it the way you want it .
Pro is an Awesome choice.
#6153 1 year ago
check out the link for a few things, the 4th item along is the metal angle brackets if you are experiencing airballs, the flipper slipper is still in test - waiting on some samples, but there are a few shooter knobs, plunger plates and even a car bracket for over the shooter lane for the ecto
Added 16 months ago:
edit:
sorry forgot to post the links
the target brackets
https://www.shapeways.com/product/GRBNG4DQK/stern-target-bracket-v2-5deg2mm?optionId=63971960&li=marketplace
and then all mods, parts, tools etc
https://www.shapeways.com/marketplace?q=swinks&sort=newest
#6154 1 year ago
Played a bunch of games on a premium on location over the weekend.
I forgot how awesome this game is - kept me coming back to pump it with quarters
Only issues with machine was the library kickout kept sending it SDTM and the dam wide flipper gaps are just not called for.
Besides that, the PF just seems like the most jam packed on any recent stern. It make BK pro look like a desert
#6155 1 year ago
wannabewizard the shaker motor is especially great for the storage facility multiball animation.
#6156 1 year ago
I went for LED Color DMD and it's fantastic. I had originally ordered the LCD version but much prefer the look of the LED and the fitment is exactly like the original display.
#6157 1 year ago
LED DMD with Comet's Glare Eliminator FTW!
#6158 1 year ago
For Premium/LE (most apply to Pro):
Install cliffy's
Adjust height of drop targets
Adjust spring on drop targets (20-25 coils up)
Check & change balls
SLIMER butt nut - check slimer positions and butt nut
Put a washer under right ball guide (blue rubber bumper) to help playfield damage
Put mylar down in shooter lane Or install Cliffy's
Get the green spring for the manual shooter rod, and the high compression spring for the auto-launcher
Align flippers
Install the plastic air ball protector and right orbit protector (CPR9999 makes the best!)
Adjust the coil power in the service menu ADJ > G.B. > Feature Adjustment #11 - Trough Eject Power. Mine is set the lowest power 176
Check 14th street subway switch to make sure ball is changing switch state
Ball guide rod 1/4" higher - hit with hammer (behind each sling shot area - this prevents ball jumping in the drain areas)
Hex spacer 1 5/8" (or 1 3/4") - change this on the right plastic 1/2 circle ramp (this shorter hex makes it easier for ball to go up).
For those interested, making another run of Airball protectors. Check out Ad and videos.
https://pinside.com/pinball/forum/topic/sale-ghostbusters-airball-air-ball-right-orbit-protectors-2
#6159 1 year ago
I was jonesing for this pin two years ago, played the Premium only about 20 times. Lost the urge but it has come back again with the news of an imminent code update. Can’t shake it. From most videos,Pro looks to be the smoothest shooter,Premium has the best toys and magna slings. Tough decision!
#6160 1 year ago
Quoted from Budman:
Imminent code update ....lol!
#6161 1 year ago
Quoted from swinks:
What link are you referring too? Thanks
#6162 1 year ago
Quoted from Clytor:
Thanks for the advice.
#6163 1 year ago
Well I suggest my Leg Lights.
#6164 1 year ago
Quoted from PinDoctor82:
The LED DMD is AMAZING. I had a shaker in mine and it was excessive, especially on containment unit multi-ball mode. I opted to shut it off and I feel the gameplay is better without it.
Same here. The storage facility multiball almost shakes the game apart.
#6166 1 year ago
Quoted from Who-Dey:
True dat. Though that’s why I love it!
#6167 1 year ago
Quoted from Spelunk71:
I did too until i started finding screws in my cabinet and saying......hmm i wonder where these came from? I guess i will find out one of these days.
#6168 1 year ago
I was going to say that the Ecto-1 lightbar topper is an essential mod. Only a few are out there for sale now, and it is expensive, but man, it's so cool.
#6169 1 year ago
Quoted from Budman:
I always say that this game has two personalities...one on location and one at home.
On location, I actually prefer to play the Pro. The right ramp on the premium can be nearly unmakeable on location if the setup and maintenance (cleaning/waxing) aren't kept up. I've never found the Pro right ramp all that hard to hit. The premium magna slings really piss me off if/when they screw me over on a game I dropped quarters into.
At home, Premium all the way. Set it up right and the premium version smokes the Pro. Keep it cleaned and waxed and the ball rockets up the right ramp. Sure the slings can do nasty things...just play another game (you've already paid for it!).
Both shoot equally well on the other shots...left orbit is tight but exactly the same on both. I find that the left ramp is easily backhandable on most Pros. My Prem can't do it at all. Flipper power and angle are stock out of the box. I just post pass and shoot it with the right flipper...second easiest shot in the game.
I just finished my Premium for the second time in two days, so I'd say it shoots pretty smooth!!
#6170 1 year ago
If I would want to replace my ghostbusters LE playfield in the future for ghosting, would they sell me one? If so, what would that cost?
#6171 1 year ago
Hot diggity damn! It looks like I am in the club!
Long story but I was in after the original reveal on an LE; deposit paid, waited out the whole time for shipping and had to give him up due to some challenges that I was experiencing at the time. It arrived NIB but a friend swooped in and took it away. Fast forward 3 years and I will be picking one up Saturday morning with a new replacement PF in the wait. I will get the pin home and set up and then arrange to do the swap. This replacement populated PF was made available due to the original plagued ghosting debacle. All that said, my day is finally approaching!
I have just ordered a full set o' cliffies but has anyone here opted for the new thinner (.5mm) Playfield protector:
https://www.playfield-protectors.com/Home/Details/jfscMWEhZk-Cw5zNSeDD2g?categoryid=22&category=Playfield%20Protectors&name=Ghostbusters%20(Limited%20Edition)%20%7C%202016
Not sure if it is overkill but after seeing the dimpling on our ACNC, that just killed me especially after opting in for the buttered cab and all of the trimmins'. Still watching that as I might be checking in with Spooky if anything else happens beyond dimpling.
I will try to go back and determine which other mods are essential or just plain fun.
Is the new audio mix done with pinball browser or is there more to it?
#6172 1 year ago
Quoted from Gost2dp:
You'd have to talk to Stern or your distro about that.
#6173 1 year ago
FINALLY..., found a used topper for sale on FB market place, be here by Tuesday!
#6174 1 year ago
Eliminate ALL those airballs with plastic protectors: (almost sold out get a set for left ramp and the right orbit shot before they are gone!!!)
B27B14E5-C7FA-4F5E-A650-547E7C9330E9 (resized).jpegCBFBF8D1-3556-435E-A445-332593193087 (resized).jpegE3DCAB70-BC50-446E-837F-B9665D6DF3C4 (resized).jpeg
#6175 1 year ago
Anyone else having issues with breaking rubbers at the right saucer? It’s the 3rd ring wich is about to break.
#6176 1 year ago
Quoted from Midway-Man:
I have about 5,000 plays on mine and have never had an issue. See if the post has any sharp edges that the ball can push the rubber against.
#6177 1 year ago
Quoted from desertT1:
I have checked it a while ago. It’s fine. My game has around 3000 plays. And this is now the 3rd ring at this place wich is about to snap. I am using Titanrings. Wich ones do you use?
Both of my drop target springs broke as well. They broke just around 20 games apart. I have the stronger ones put in.
#6178 1 year ago
Mine is literally bone stock, aside from 2 things. My friend got me the slime spotlight covers from Mezelmods, and I have an extra ball behind the librarian captive ball because I got my game before they figured out what was causing the wire to bend.
#6179 1 year ago
shopping a GB for a friend. Going to add a few mods...are colored rubbers nice looking on GB? thinking slime green if they have them.
#6180 1 year ago
dont see the slime green covers on their site?
#6181 1 year ago
Just hooked up my ColorDMD. Can someone tell me how to get it to use all the colors. I can only seem to choose one color . Probably something simple,I’m a newbie tho, any help would be appreciated .
#6182 1 year ago
Quoted from billrz:
did you download code for their site and install?
#6183 1 year ago
Quoted from billsfanmd:
I just did Titan clear rubbers in gb. Green flipper rubbers Looks slick!
IMG_20190520_204340724 (resized).jpgIMG_20190520_204406824 (resized).jpgIMG_20190520_204350890 (resized).jpgIMG_20190520_204355313 (resized).jpgIMG_20190520_204421837 (resized).jpgIMG_20190520_204325070 (resized).jpg
#6184 1 year ago
No. I did not. Is that the issue?
#6185 1 year ago
Got my LE home on Saturday!
Added a couple of homemade mods already.
I wanted the books to be much taller than the mods that I've seen online. Lucked out with this set from a local comic book Shop. Made some custom brackets and voila! It's going to be fun modding this
IMG_20190519_0917181 (resized).jpgIMG_20190520_1631043 (resized).jpgIMG_20190520_1631219 (resized).jpg
#6186 1 year ago
Quoted from billrz:
Yes, colordmd website has instructions. This must be done for every title.
#6187 1 year ago
Quoted from billrz:
Yes. Go to their site. Download code to thumb drive. There is an example of a guy doing whitewater on the site. Very easy
#6188 1 year ago
Quoted from yzfguy:
[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Do you have list of sizes you ordered ? Thx !
#6189 1 year ago
Oh, man. I had them all written down when I ordered for all my games but I combined them all into one big order. I think I found the sizes online.
#6190 1 year ago
Thanks. Got the color installed. What a great mod !!
#6191 1 year ago
Quoted from billrz:
Did you order the LCD with add-on mounting kit? Just ordered the display bundle, looking forward to it!
#6192 1 year ago
Quoted from yzfguy:
Order from Pinball
Life or titan ?
#6193 1 year ago
I'm interested in a full rubber kit as well, if we get a proper list together it would be greatly appreciated.
I saw pics of the glow titans on the ACNC and they look killer. Maybe the same for GB?
#6194 1 year ago
Order from Pinball
Life or titan ?
Ordered from titan.
I ordered some glow post sleeves from them for AFM, and the flow rubbers might also look cool. Here's a shot of them on AFM for reference.
#6195 1 year ago
Quoted from yzfguy:
Ordered from titan.
cool i need to get a rubber chart so I can see what I need
#6196 1 year ago
If you are going to order from titan, they have the very cool game database. It lists games and has all the sizes you need. Check it out.
#6197 1 year ago
Quoted from DudeRegular:
Thx. Just looked. One of the kits has all glow rings. would love to see pics...
#6198 1 year ago
Last day in the GB club for me, great game but onto the next!
Keep on flippin and always remember, if ‘bustin doesn’t feel good... why do it?
#6199 1 year ago
Im shopping a GB pro and the only issue my friend was having is an intermittent right flipper. Ive fixed many flipper issues on older pins. usually its the leaf switch not making contact when press button the leaf switch out of alignment. In test mode it seems to work all the time. Im watching through the apron and the leaf switch looks perfect even when it wont fire. Is this a potential node board issue? never really had to troubleshoot spike pin. Ill double check the leaf switches this weekend but at first glance they look like they are making contact at the right gap.
#6200 1 year ago
First thing I would check is it running latest code 1.13? There was a software related issue in earlier code versions regarding weak flippers. This could be your problem.
$ 48.00
New York, NY
$ 27.00
$ 50.00
$ 199.99
