(Topic ID: 252385)
*NEW* Ghostbusters 1.17 Custom Mix - Bobby Brown and Higher and Higher
By delt31
11 months ago
  • 77 posts
  • 30 Pinsiders participating
  • Latest reply 6 months ago by Mrjamma
  • Topic is favorited by 17 Pinsiders
There are 77 posts in this topic. You are on page 1 of 2.
#1 11 months ago
Premium and LE only.
Bobby is back - latest code (17):
https://1drv.ms/u/s!AsQD4DkcjPIPgbBfnoUdEhgWGz7ujA?e=RzE79e
Edit - to install this you do the SAME thing you would do when updating your code. Download the file via this link and follow the same instructions Stern provided when young code.
Jurassic Park Update coming as well....
#2 11 months ago
Quoted from delt31:
Premium only.
Updates my older code. BB On our Own and Higher and Higher included
PREMIUM only.....enjoy
https://gofile.io/?c=9VgH9V
Can't wait to try it. Thanks!
#3 11 months ago
Quoted from delt31:
Premium only.
I hate to sound like a new any instructions on how to install this? Is it the same process like doing a update?
#4 11 months ago
Same process and well worth it!
#5 11 months ago
Quoted from delt31:
Premium only.
Awesome! I'm going to download this today. Thanks!!!
#6 11 months ago
How do you reverse it if for some reason you don’t want? Anyone have a video of what are the changes or have a description of what’s added?
#7 11 months ago
Which songs/modes do these replace?
#8 11 months ago
Quoted from Blackzarak:
Reversing it is as simple as re-installing the stock code.
#9 11 months ago
Quoted from delt31:
Premium only.
How do i do it
#10 11 months ago
Any plans on a pro version?
#11 11 months ago
Quoted from johnny77:
How do i do it?
You install this code the exact same way you install the factory code. Download the code to the root directory of an empty USB drive. Power off the game and insert the USB drive into the USB slot on the game. Turn the game back on and follow the instructions.
#12 11 months ago
Awesome. Thanks
#14 11 months ago
Hmm... I wasn't able to install it. It recognized that an update was in, and said to select to install it. The game paused for a few minutes, and then said it was installed, but it didn't show the progress bar or anything. It rebooted normally, but it is the original 1.16 code. I tried redownloading it but I got the same error. Has anyone else had any trouble?
EDIT: Just saw you reposted a new version. I'm trying that now.
#15 11 months ago
Hmm, I tried several times, but my download stops at ca. 1 MB...
#16 11 months ago
so I've had it happen too where it says installed but no way b/c too quick.
My fix was to change the USB stick and my other usb stick worked no issue.
#17 11 months ago
I was able to get it downloaded and installed. It’s awesome!
Thanks, man!!!
#18 11 months ago
Sorry, maybe already discussed. But what is the difference with mudflaps version?
#19 11 months ago
Quoted from delt31:
I tried two thumb drives. Same issue. This is literally the same thumb drive I used when I installed the original code and other updates. Can't get it installed just yet.
#20 11 months ago
I'm having the same problem. I know the drive is fine, as it's the same drive I used to install 1.16 the other day.
Edit: A different USB drive worked. Very strange.
#21 11 months ago
For anyone having issues, I would recommend you do a fresh format (FAT32) to your USB (even if it worked for previous code install)... I always do this first before adding any new files.
#22 11 months ago
UPDATE: It is installing now!
I promise you all, I have used these two USB sticks countless times to update the code on this machine and others. After all of your reports, I tried other sticks. 6 USB sticks in, I concluded that it must not be the stick. But I have 9 thumb drives and kept going. The 7th stick worked.
Weird.
#23 11 months ago
It could be a hosting issue. My download kept stalling, but I was eventually able to get it to go.
#24 11 months ago
Try downloading to your desktop first and then copying to the usb drive.
#25 11 months ago
I did install it took and works but it seems like new music is lower in volume. The sound effect sound lounder. Any advice. Yes i turned up volume. Lol
#26 11 months ago
Get the latest version that I posted. Should be better
#27 11 months ago
Does this work for the LE?
#28 11 months ago
Quoted from Pinhead1982:
Yes - I'm on LE. I should make that clear.
#29 11 months ago
Amazing turn around...I was excited about the code update (and Stern Dev's deserve a huge kudos), but was going to hold off until the custom audio was tackled...just updated, there's lots of pink slime everywhere
Thanks again !!
#30 11 months ago
Just got this update installed, thanks for adding the beat back into the Spooked Librarian! I thought I had installed the wrong code till I heard Bobby B, was pleasantly surprised!!
Fyi when I get to the highscore screen it isn't playing Higher and Higher while I select name/initials, doesn’t play it until after I hit 'enter' to save the name, then it only plays it for a split sec and then its back to attraction mode.
#31 11 months ago
Is there a list of what was changed? Thanks for the work again really appreciate it.
#32 11 months ago
Quoted from delt31:
So i can just upload new version of music in to game. It will rewrite over old.
#33 11 months ago
Quoted from ArcadeBar:
Fyi when I get to the highscore screen it isn't playing Higher and Higher until after I hit 'enter' to save the name, then I only hear it for a split sec and then its back to attraction mode. My dload timed out sev times when i was trying to get this update and took me a half hour so I wasn't sure if my code might have got corrupted or if something changed on 1.16 to throw Higher and Higher off on this remix...?
You have an older version. The latest posted last night fixed this as I noticed the same.
#34 11 months ago
Yes.
#35 11 months ago
although I don't do personal requests, there was some interest in keeping the librarian mode the same as the original which I've done in the version below. So basically my updated code but the librarian mode music is kept stock (which is a little more upbeat).
https://gofile.io/?c=uNRBFQ
#36 11 months ago
What has changed to the original music. Is there an overview?
#37 11 months ago
is this the same as mudflaps version?
#38 11 months ago
Quoted from bent98:
Similar but not identical. This is the same setup as the previous code where it has music from the movie and then bobby brown and higher or higher (which I don't believe is in mudflaps).
#39 11 months ago
I installed this version in my GB Premium with no issues. Its sounds great! -thanks for the effort.
#40 11 months ago
Delt31, I am not sure if your aware buy 1.17 code was released yesterday,
#41 11 months ago
Thanks Stern's too quick for me but I'll update this weekend or following
#42 11 months ago
Thanks for doing this!!
Quoted from delt31:
#43 11 months ago
Agreed. Looking forward to it
#44 11 months ago
Quoted from Jimmyapple:
I second that!
#45 11 months ago
You discriminating againt pro owners or what?
#46 11 months ago
Not at all.... Just not stepping on mudflaps effort as he currently is providing pro version.
Been busy so this has taken back seat. I haven't even updated my code yet. I'll get to it though
#47 11 months ago
Hi Delt31, Any update on releasing new code?
#48 10 months ago
Quoted from bent98:
Just checking in also!!
#49 10 months ago
Sorry for the delay guys. I've been focusing on Jurassic Park code bc it needs it much more than GB. I'll eventually get back to GB but the recent Stern upgrade it's pretty minor so I've been content not even updating.
JP on the other hand needs some TLC. I'll eventually get back to it and will post here.
#50 10 months ago
We'll get there on JP. It's a lot of front end work getting some really great clean audio, but we've already got nearly a hundred replacement clips ready.
$ 495.00
MI Pinball Refinery
Hixson, TN
$ 12.99
Bent Mods
$ 54.99
$ 22.00
