Thanks for sharing.
It appears some Pros coming out are getting assembled a little different.
Heres a Pic to ovalize the Protector Holes, it can go in the other direction, if needed, that will allow
some adjustment with regard to targets or slimer.
I heard from another customer, who too a dremel and sanding disk, and by viewing top down, fingernail cut out a small dent area for Slimers Butt.
Equally, is something I havent done, as I dont have a Pro is the Switch adjustment...Thank you for Sharing!!!
I have heard and done a shim on the Boom Mechanism below the playfield with washers under the back side, or front as needed to simply change the whole angle.
Interesting, as the variation seems to be up to 5mm in Assembly in distance variation
