(Topic ID: 158288)
Ghostbuster Issue Thread
By exflexer
5 years ago
  • 4,494 posts
  • 532 Pinsiders participating
  • Latest reply 21 days ago by cpr9999
  • Topic is favorited by 147 Pinsiders
55 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 4494 posts in this topic. You are on page 30 of 90.
#1451 4 years ago
Thanks for sharing have you done anything with the foam at the librarian scoop? That the other area that generates air balls.
#1452 4 years ago
Quoted from Jive:
Fyi, I believe I have fixed my airball issue without using any type of protector/shield. Took two small pieces of weather stripping, and stuck them to the back of the targets at the very top. Now, when the target is hit, it stays angled down, and does not launch the ball. Played seven games, and really tried to hammer both targets. Not one ball came off the playfield. I think this is similar to an idea that was posted earlier in this thread, but I did not remove the stock padding. YMMV.
I did the same thing to my stand ups. Helped a ton. Even a softer weather stripping doesn't allow the target to snap back fast enough for the ball to get lift.
#1453 4 years ago
Quoted from NeilMcRae:
No, but I will look into it.
#1454 4 years ago
Quoted from HOOKED:
Humm me thinks it may be my lucky day.
How the heck did you land #500.. I thought Cointaker always had dibs in the last LE?
#1455 4 years ago
Quoted from Concretehardt:
No clue - but CT always takes care of me - Melissa and Chris are great to work with.
#1456 4 years ago
so I realized the power of the shooter is really strong on this one. How do I reduce the strength so the ball doesn't fly out too fast?
#1457 4 years ago
Ran into this problem this morning. On the new code, I was having my best game so far on my Pro. When I reached Stay Puft I hit the left ramp. As soon as I did that, the DMD said "RESTARTING GAME…" I thought this was the new scare feature and prepared for my machine to scream at me. No scream...just game over. Anybody else come across this?
#1458 4 years ago
Hey guys,
I lifted the PF yesterday on the Prem to install the art blades and noticed a sticker on the left side that was handwritten "Harold LE"
I might have a look under the apron and see if there's a signature like the one that was found in an Aussie one.........
Not sure how many games in, but quite a few and (touch wood) no issues so far except for a small amount of CC chipping in the shooter lane which I've mylard and will get the cliffy lane protector. I reckon that's a must
#1459 4 years ago
My ecto goggle are acting wonky I keep getting a blank screen and occasionally a fast scroll of the ghosts sideways
Any thoughts
#1460 4 years ago
Quoted from Hdmike444:
Any thoughts
I've seen advice for reseating the connection on the board for random issues like this. Let us know if it works.
#1461 4 years ago
Yes I tried that several times and also tried re-doing the code but nothings working
#1462 4 years ago
Quoted from rooky79:
1) Under Feature Adjustments #11, you will find 'Trough Eject Power', I have mine set at 240- you may wish to lower yours until it's at a ball eject power which will help to reduce possible shooter lane chipping.
-Thanks to JMK for this tip. Hope you guys find it useful as well. I minimized mine, just because I see no reason to have it rocket out of there. It can only reduce wear on the game in my opinion.
#1463 4 years ago
Has anyone had cabinet issues like this?
Right corner:
Left corner:
Another angle of left corner:
Oddly, the decal on the outside is fine. This leads me to believe that the cabinet was like this before the side decals were installed.
#1464 4 years ago
Quoted from Chambahz:
Wicked cheers mate I'll do that.
I wondered if it was possible but couldn't see it
#1465 4 years ago
In an effort to reduce/eliminate the airballs off the left ramp on my pro I did the following. I remove the target assemblies and bent the mounting point of the bracket about 5 degrees. These brackets are tough so you may need 2 pairs of pliers. I used a vice grip to hold and pliers to bend. Make sure you bend it the right way too and don't over do it! About 5 degrees (roughly) is all you need. The difference is very noticeable now. Edge shots off the targets bounce slightly off the playfield instead of being ballistic moon shots. You cannot visible tell anything was done either because the angle change is slight.
Edit: It does not 100% eliminate airballs, but significantly reduces them. I was playing and trying to cause airballs by hitting the 2x and 3x targets. I did get a medium airball off the 2x once. Most other times the ball just bounced about 1/4 inch or less off the playfield.
These target brackets are really well designed and strong! The design even keeps them from fanning out sideways.
Rob
#1466 4 years ago
Quoted from Jive:
Right corner:
Left corner:
Some people have had similar cabinet issues. Namely the font corners coming apart and the wrap around decal tearing.
Rob
#1467 4 years ago
i'd be pushing for a new machine if that was mine, thats only going to get a lot worse.
#1468 4 years ago
Ive had this but only once - how often are you seeing it? I put it down to buggy code...
Neil.
#1469 4 years ago
I think we need pictures of cabinets so we can understand how it's supposed to look
#1470 4 years ago
Neil.
Last 4-5 times I have played it it is blank
And I have power cycled several times too
#1471 4 years ago
Guess I will call Stern and see what they say.
#1472 4 years ago
Also be sure to cal your distributor
#1473 4 years ago
Never mind..
#1474 4 years ago
Can someone please post a picture of the autolaunch coil assembly. I need to know where the paper piece goes.
Nevermind, the manual shows it.
Rob
#1475 4 years ago
I (really) stretched out the spring on the autolauncher coil and it seems enough (so far) to keep the autolaunched balls under control. It's a weak spring so it may not last, but it's worth a shot since I don't have another suitable spring right now.
Rob
#1476 4 years ago
Hey guys,
I lifted the PF yesterday on the Prem to install the art blades and noticed a sticker on the left side that was harold.le handwritten
mine also had the handwritten sticker.
#1477 4 years ago
just thought I would post my fix for the blinding lights on the premium and le near the slingshots. I have placed a thin green piece of electrical tape over the 4 little boards and now the light is not blinding and is a pretty green.
#1478 4 years ago
Quoted from mcfly:
Can you post a pic? Thanks
#1479 4 years ago
Quoted from ronaldvg:
Hi Guys, I may be on to something here: Look at the attached pictures. They were taken under the same light conditions with the same camera at the same time (10 seconds apart).
The colors are very different. In one the overalls are brownish, in the other more green. This is in real life also the case. The more brownish one does have ghosting (look at Tobins) and the greener has not.
Overall the one with the greener overalls does have much better colors such as the blues and the purples. The other playfield looks more washed out when looking at it directly.
Maybe we can confirm this is the same for all playfields that are having ghosting ?
This would lead me to think stern has several Different manufacturers again.
I Said this before regarding hand written pf dates vs stamped.
#1480 4 years ago
I'm waiting till January to buy my Pre!!Dealer told me they should have the new code by then,and have SOME of the pf issues delt with!Those airballs are tough to fix them all!! Thank you guys for all your great help in taming this beast!! Be back in Jan.
#1481 4 years ago
I haven't read all the posts but has anybody had there clear chipping in the shooter lane? After about 50 games I looked down and saw mine had chipped all the way to bare wood. I have a premium Sept. 26 playfield. I've got games 10-15 years old with no chipping in the shooter lane. What is going on? I don't have any ghosting yet and hope I don't!
#1482 4 years ago
I'll get a pic for you Tomorrow I'm very happy with it because now I can do loopin supers without getting blinded.
I just cut a small piece of light green electrical tape and placed over the leds on each board then screwed them back in. It was just enough tape to cover the 3/4 of the board with the led. Pic coming still
#1483 4 years ago
Quoted from PinballHog:
I haven't read all the posts but has anybody had there clear chipping in the shooter lane? ...
my 1st GB (with ghosting) get same chip there the very first day we've played with it !!! was quite stuning, just few games and already marked
my 2nd one (with no ghosting) has just nothing
seems its an easy conclusion... :/
#1484 4 years ago
What is written in pen to the left of the date stamp, looks like a hand written date ?
#1485 4 years ago
Install the new code and turn the ball eject power down to 176 (lowest) as soon as possible. The default eject power is way too strong and that's why it's chipping.
Rob
#1486 4 years ago
Quoted from HOOKED:
this one? My premium is a Sept 26th build with a Sept 23rd hand-written pf date.
#1487 4 years ago
Quoted from golfingdad1:
It says 9-23
#1488 4 years ago
I got a confirmation from Chas at Stern that putting in a stronger spring above the autolaunch coil can help reduce the kick and should not have any long term negative affects. I have noticed much smoother launches since the switch.
#1489 4 years ago
Quoted from Rob_G:
Rob
Yes, I had a problem with my front left corner. There's a layer of plywood on the front face that pulled away and tore the decal. I need to use some wood glue on it.
#1490 4 years ago
Ok thanks,
My guess and only a guess is this playfield was made by one of the manufacturers, the one using a sharpie to date their playfield, then it was reinspected by Stern 3 days later for final approval.
#1491 4 years ago
Ok thanks,
Was this playfield date supposed to be one that the ghosting was fixed. I still haven't seen any ghosting and I put several more games since the clear chipping showed up.
#1492 4 years ago
Who really knows .
These dates are showing some chipping in shooter lane and the ball trough, but the ghosting seems to have almost gone away, maybe a few reports of minor ghosting but not spreading like the LEs .
#1493 4 years ago
But then this was just posted, but also the pf Dat of 9-8 is hand written with no secondary date stamp.
#1494 4 years ago
Quoted from nowakster:
Called Stern and talked to Chas. He wanted me to send him pics of the cabinet, and said he would discuss it with the boss and get back to me. Really unsure as to what they can do, other than replace the game which I highly doubt. Even, then, I'd be rolling the dice as my current playfield does not have the ghosting issue.
#1495 4 years ago
Quoted from Jive:
Sh!t , keep that playfiled and have them send you a cab.
#1496 4 years ago
Quoted from mcfly:
I'm stopping on the way home and getting some today.
#1497 4 years ago
Quoted from jaystile:
Where do I find this different spring? I don't want mine to chip.
#1498 4 years ago
I don't think the autolaunch causes the chipping. Just bad behavior down the lane... hitting stay puf, etc.
The overpowered ball eject (from the TROW! hi kanada) is what divots and damages the shooter lane in the pics we've seen.
That, and the fact the clear doesn't seem to adhere to the wood properly. Bad combination. There are several rube goldberg type of ways to calm it down or last resort you could put a much less powerful coil in there. Not sure why Stern thinks it's appropriate to blast the ball into the lane with such force.
#1499 4 years ago
I agree, after re reading this my eject is what I'd like to power down a little bit.
#1500 4 years ago
There seemed to be some confusion. According to the manual the 'Eject VUK' (Vertical Up Kick) coil is what causes the chipping in the shooting lane. The coil power can be adjusted in the service menu ADJ > G.B. > Feature Adjustment #11 - Trough Eject Power. Mine is set the lowest power 176. This helped a bit, but I have also installed a cliffy protector.
The other issue is the 'Auto Launch Assembly' firing way too hard. I was worried that is was going to crack the plastic on the back as most of the time the ball ricocheted off the wall into Stay Puft or came bouncing back down the shooting lane. This is what the replacement spring fix is for. Easy to replace.
1. Unscrew
2. Compress spring to raise up the coil off the coil stop.
3. Rotate everything out of the way, replace the spring, and reassemble.
