(Topic ID: 158288)
Ghostbuster Issue Thread
By exflexer
5 years ago
  • 4,494 posts
  • 532 Pinsiders participating
  • Latest reply 18 days ago by cpr9999
  • Topic is favorited by 147 Pinsiders
55 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 4494 posts in this topic. You are on page 23 of 90.
#1101 4 years ago
Quoted from Tseamans:
My ghosting started on Tobins, I also got some pretty serious chips. You can see pics here.
https://pinside.com/pinball/forum/topic/official-ghostbuster-all-things-lepremium-club/page/4#post-3300352
You're about to challenge KPG for "worst big chips". Sorry to see it - send those pics to Stern pronto.
#1102 4 years ago
Dont know what this is.......but checked all connections beneath and its all good.. For some reason i'm getting dull flickering lights from the one section from time to time....super jackpot red arrow hardly lights up at all. Airballs are insane on this and the general build quality is pathetic ie: insert ghosting, ball plunging into everything upon entry....really questioning whether to keep my GB at all.
#1103 4 years ago
Also had a couple of other weird issues last night:
- game completely reset on a tilt
- Tobin awarded esp, but it didn't light at the right scoop. I didn't collect, but it lit on start of next ball.
Anyone else had these?
#1104 4 years ago
The air balls and crazy plunging can be fixed in two shakes,but the other stuff sorry
#1105 4 years ago
Quoted from pinballcrazed:
I had crazy flickering in this area too. Turned out to be a loose connection to the ecto goggles. That doesn't help you specifically but I would triple check your connections.
#1106 4 years ago
Just got me GBLE last night. 396/500. August 2/2016 date on back.
Before turning on we checked all connectors and most of the nuts and screws on the topside. There were several connectors that needed to be pushed in fully and several nuts/screws that needed turns (not bad overall).
I did notice someone at the stern factory busted out the sharpie to cover up some damage to the head trim.
We played about 30 games last night.
Slimer: I do have "Slimer drag" and the beginnings of wear on the metal. He registers hits 97% of the time so I'm happy with that. Going to try the Mitch washer fix.
Ghosting: I see 2 inserts ghosting so far.
Drop targets: I needed to lower both of them as they were above the playfield a bit. No big deal. They drop just fine. No issues there.
Negative reinforcement insert: correct spelling
Guide rails: Not sure if mine are the original height or the new height but we had several balls hop over.
Full plunge feed: I do get some rejects but I think a green spring solves that from what I have read so no biggie there.
I did add mylar to the side rails to prevent the lockbar from damaging them.
Lollypop rails. I have the mismatched pair.
Odd issue: One time an airball got stuck on the left plastic. The ball save kicked in and the vibration freed it but shortly after the display read "resetting" or "shutting down" or something like that and the machine reset itself. At the time of the reset Slimer was to the far left which looked odd since I had never seen him that far left before. Not sure if that is relevant or not. After the reset, the high scores we had just put up were deleted. Anyone have this happen? and/or know what the heck happened?
Airballs: Check. Plenty of those.
Captive ball wireform: I think mine is fine. Can someone let me know if mine is the original gauge. I think I read newer GBLE's have a thicker gauge wireform.
Missing screw/washer: After about 5 games a screw and washer came flying from somewhere. 3 of us looked diligently for 5 min and could not find where they belong?
Subway ramp: So far so good.
Playfield damage: See the pic with the negative reinforcement on ESP ability insert. Not sure what is going on there?
Let me know what else to look for or if I missed anything. If you have any questions feel free to ask.
#1107 4 years ago
Quoted from atariaction:
Wow what a disappointment for nib le ..... good luck
#1108 4 years ago
You do have the new captive ball improvement but negative reinforcement looks really bad not sure the issue maybe vid or someone else hear can shed light on it i would suggest you post there in the hey are you serious stern thread.
#1109 4 years ago
Wow man. Terrible condition out of the box. Whatever is going on in that negative reinforcement pic is surprising- I can't believe this thing made it out of the door at Stern.
Definitely start the communication with your distributor about making this right.
#1110 4 years ago
Quoted from kpg:
Maybe we need a "Fix My Playfield" Facebook campaign, nice avatar.
-1
#1111 4 years ago
I have to give Stern the benefit of the doubt and suspect even they would not say this is supposed to pass as a NIB LE, or even a NIB Pro.
Sorry you have deal with this.
#1112 4 years ago
Man I hate to keep being negative , trust me I'm hoping for the best, but apparently things have not got any better . How can they keep shipping this stuff.
Sorry to see those pics on a brand new machine.
#1113 4 years ago
Anyone know the cause of the damaged it looks like a sticker was pulled up reveling the wood or something.
#1114 4 years ago
Sorry to see this. Painful to see really. The fact that all GB LE's are not on a "DO NOT SHIP" list at Stern is baffling. How can they ship games out knowing this issue exists. Hard to believe this issue won't eventually plague every GB LE. Really dumbfounded by Stern continuing to ship out machines.
The mismatched side rails are probably the ultimate sign their Quality Control is laughable. Gary, how'd you miss that one?
#1115 4 years ago
just when you thought things couldnt get worse. what a sh#tstorm!!
#1116 4 years ago
The splitting artwork above the negative reinforcement insert is the most disturbing.
#1117 4 years ago
I get how a playfield could look perfect when you install it and then develop issues en route to customer. But two different lollipop rails? How do you miss that?
#1118 4 years ago
Quoted from JVC10:
This is just a total lack of QC this is getting nuts how many problems GB is having
#1119 4 years ago
Are you sure that's just not just wax/etc on the edge of the mylar?
The same colored grit can be seen in the insert area too, not just the wood. Just looks like dirt on the edge of the mylar.
#1120 4 years ago
Quoted from Flato:
Let us know how yours turns out when you unbox it , Tomorrow ?
#1121 4 years ago
Thought I'd share how I (finally) fixed my Slimer dragging his butt all over the place.
Below is a link to my first attempt - which is the same fix as the "add a set of washers" fix but I just raised it and tightened the set screw because you don't really have to have the washers. ... his butt still hit in 2 places.
https://pinside.com/pinball/forum/topic/official-stern-ghostbusters-speculation-thread?tu=mt45#post-3272845
My newest fix involves leaving the "washer raise it up" fix in place because you DO gain height.
Then I saw another Pinside say that he pulled up on the wire on top of the Slimer switch mech/arm and zip tied it. He is correct in that there seems to be about 1/4" or more of "play" so that you can grab that top wire above Slimer and if you gently pull it up, it raises Slimer that amount above the playfield. Now ... to get the wire to stay there.
I could not get the zip tie to stay tight, so I cut a 7/16 post rubber and slipped it around the wire on the top of the mech/switch/arm
Worked like a charm.
I think the Slimer registers side hits a little easier now, but other than that he does NOT rub/drag at all!
First video is with ONLY the "washer raise it up" fix in place - again he still drags
Second video is with the 7/16th rubber in place (see pic for close up of it installed)
Cheap and fast fix!
Dragging Butt
FIXED!!!!
#1122 4 years ago
Wow. Looks like a shitty piece of Mylar put down.
Inserts ghosting already.
Same build date as mine.
Hard to believe what is going on here.
It's like PF Russian roulette
#1123 4 years ago
It's unbelievable with all this negative attention that Stern can't get its S together. At this point Gary or George should be at the end of the line ensuring every game is damn near perfect. I really don't know how Gary can continue to ship this with his name on the box.
It's also a shame that GB is a great game that is a dream theme for a lot of people and a game that should have propelled Stern but is instead turning into a total nightmare.
#1124 4 years ago
Quoted from MT45:
Cheap and fast fix!
Dragging Butt
FIXED!!!!
Glad you got this to work!
#1125 4 years ago
why mess with raising slimer up more then the 2 washers just remove him and trim the bottom wire on a bench grinder.
#1126 4 years ago
heres what the playfield looks like when you try to move the outlane posts!
#1127 4 years ago
Quoted from forensicd:
Oh boy.
Is Stern clearing these with a populated playfield?!?
#1128 4 years ago
Same thing happened to me day one of ownership
#1129 4 years ago
Quoted from Mitch:
Not sure that would have helped mine. The wire never hits at all, it's so low that Slimers side hits first. Did you mean to remove that wire compression fitting on the bottom altogether, then cut the wire shorter and install the compression nut higher? I considered that but wondered if the compression piece would be destroyed when removing it ...
#1130 4 years ago
Pathetic. This is such a huge problem that I can't even fathom how long it will take to make this right with all of us.
#1131 4 years ago
Quoted from golfingdad1:
Its being shipped to me tomorrow will probably get it Monday but whenever i receive it will document the entire process good or bad..........
-2
#1132 4 years ago
Any one who has a issue should file a consumer complaint.
Let's start a petition list which nrs of LE have issues.
I don't have mine yet but I don't have much hope in getting a perfect product for $$$$
#1133 4 years ago
Yeah if Stern were a football team they might be classified as being in the "all-rookie rebuilding phase". Maybe they actually DID lose an entire division of people that knew what they were doing but this is getting painfully embarrassing.
You open the box of their most expensive top-of-the-line product and you get mismatched rails, sharpied up damaged cab, ghosting inserts and chipping clearcoat, ugly "metal ruler" fix for the poorly designed wire ball guide, ugly wire "fix" on the top of Slimer who STILL stumbles all over the PF. This along with JT's slapdash design work that includes massive airballs and inlanes that can't keep the ball in play.
What's most disturbing is the customer can fix Slimer's butt from scratching up the game in an evening but when the company was asked about it earlier they say it's "normal game behavior"...as if think it shouldn't or can't be fixed. Have they either gotten this incompetent, or uncaring or have simply forgotten that in the pinball hobby... details matter?
Look at the Hobbit, Big Leb and RZ... these can have issues too but the companies at least SEEM to care. Maybe this is just good PR work but if so Stern is losing the PR war. It's starting to look like they could care less what you pull out of the box... seems like there's no pride left at all in what they deliver.
Makes me sad... but c'mon Stern - Git back yer mojo! Now!
#1134 4 years ago
Your captive ball wireform already has the Stern "fix" installed. Looks like a metal ruler shoved in there that also has the dubious distinction of blocking the light and making the area there less attractive.
I guess an actual thicker wireform was out of the question
#1135 4 years ago
Quoted from MT45:
No never remove the compression end. Sorry thought your wire was dragging. Mine doesnt drag anymore but still hit the building above the pops
#1136 4 years ago
What's that brown cardboard looking pattern to the left of the post?
Edit: Nevermind, star post. My Ghostbusters playfield conditioned mind thought it was exposed planking or something.
#1137 4 years ago
For those of you who don't want to add plastics to your playfield I dealt with the airballs differently, initially by bending the 3 guilty standups targets forward. This fixed most airballs for a while but as time goes on they tend to straighten so today I replaced the foam on these targets with thicker foam cut into a wedge shape with a stanley knife. My machine is now back to very few airballs. The foam is pretty much the same as that fitted but 10mm x 10mm cross section before cutting into a wedge. Cheap enough on ebay.
#1138 4 years ago
Quoted from robotron:
It's going to be a big shit storm. Lol.
#1139 4 years ago
That's what Gary's bathroom looks like now. Ed
#1140 4 years ago
Is this new larger mylar peice standard now? I have a much narrower peice that ends before arrow.
#1141 4 years ago
Does anyone have the ability to make a new ramp flap that is shorter for the left ramp to prevent the airballs? Look at the pro-type's in the videos, the flaps were behind the targets, so no airballs from targets. Question is did the shorter flap cause other issues that we are not seeing?
#1142 4 years ago
Has any made plastics to stop airballs yet?
#1143 4 years ago
Quoted from marspinball:
somebody working on these. they want to check to see if stern gonna make a fix kit before they invest more money into this mod.
^^^oldpinguy
#1144 4 years ago
just DIY, lots of examples already in previous post
#1145 4 years ago
Working on em......
#1146 4 years ago
Quoted from Leachdude:
My pro still gets the occasional airball from the target at the ramp entrance.
Rob
#1147 4 years ago
Quoted from OLDPINGUY:
Working on em......
Will you be offering clear ones as well as protectors with graphics?
#1148 4 years ago
No idea yet.
I have our friend in Europes Template, a thinner, longer one that anchors on the left, and a hybrid longer one.
Depending on this, might factor into graphics.
Ill know something hopefully in a week. I prefer not to abandon it, but politely request no PMs at this time.
#1149 4 years ago
Thanks everyone for your concern and support! I appreciate it. I'm starting communication with distro today.
Quoted from flynnibus:
Well good and bad news. This area was not damage but wax as you suspected so that is a big relief. But as I looked closer I see ghosting on the insert above (ghosting insert number 3 now).
Quoted from Manic:
I'll have to take a closer look at this. I did not notice the metal ruler solution.
Quoted from imharrow:
Is this new larger mylar piece standard now? I have a much narrower piece that ends before arrow.
I would assume so.
I may try the compression foam solution above for airballs. Good idea!
#1150 4 years ago
I would assume so.
That's a relief. I still find the dual pieces of Mylar odd...why not just one piece cut right?
