Bought a Mata Hari with acknowledgment of intermittent ghost scoring. I would adjust and clean drop target switches. Would be fine then start again and I repeat checking and adjusted switches to perfection. Finally after a week of this problem the flippers and beating on playfield started making continuous scoring only when right side targets were dropped. Pulled up playfield while in game. Sure enough hit flippers points would score but no switches moved. Could tap on drop target housing and points would score no switches moved. After doing this for about 30 seconds it stopped. So I said hmmm again. So I put 1/16” turn on all switch stacks. Hummm loose screws still could not get it to score again beating on it or using flippers. So I started pushing on all diodes. Bingo! It started scoring! A loose diode wire through a switch hole with solder on it looking good but would slide around. Resolder it and last problem of this game is fixed! Also what is a photo without a burned up coil replaced!
4D2B5AEB-1ED7-4252-8205-5F68F31BDA64 (resized).jpeg6011BD5E-88DF-4A4F-90BE-5F7146A37956 (resized).jpeg
