I have a small piece of the headbox decal peeling on a NIB Metallica. When i push it down it looks fine but peels after a few hours. Is there a specific adhesive i can use to make this stick better yet not make it look weird? Thanks in advance!
Quoted from xbmanx:I have a small piece of the headbox decal peeling on a NIB Metallica. When i push it down it looks fine but peels after a few hours. Is there a specific adhesive i can use to make this stick better yet not make it look weird? Thanks in advance!
Did you try using a hair dryer to heat it up alittle? If its not peeling to bad it might work
Quoted from Phbooms:Did you try using a hair dryer to heat it up alittle? If its not peeling to bad it might work
i did not try this - is it known to help?
Quoted from xbmanx:i did not try this - is it known to help?
If its only peeling alittle it can work but no promises. It all depends on if the adhesive can get tacky enough from the heat but if the adhesive is no good no more it wont work. Ive done it before and it worked and didnt work just depends on how much is peeling and if adhesive is good still.
Otherwise if it doesnt work just call your distributor or if you bought it used call Stern directly and they will send new decal.
Quoted from Phbooms:If its only peeling alittle it can work but no promises. It all depends on if the adhesive can get tacky enough from the heat but if the adhesive is no good no more it wont work. Ive done it before and it worked and didnt work just depends on how much is peeling and if adhesive is good still.
This page was printed from https://pinside.com/pinball/forum/topic/getting-peeling-decal-to-stick-on-metallica and we tried optimising it for printing. Some page elements may have been deliberately hidden.
