Quoted from pb456:I use a glass bed on my Ender 3, Tevo Flash, and Geetech A20M. Just glass, no glue stick, no hair spray, none of that. The technique I use is to get a little closer to the bed for better 'squish' (adhesion from the hot PLA to the bed), and to clean very well with denatured alcohol every two or three prints.
Another thing I use is first layer, I have the fans turned off, print at about 209 usually depending on PLA type, slow it way down on the first layer, and don't engage the fans until the second layer and only at 40%, third layer at 60% and fourth and higher layers at 60%. I've eliminated 'stringing', too strong of a bed adhesion, and most clogs - but I've found that some filaments require more tweaking. I use Simplify 3D almost exclusively (sometimes I use Cura when I'm lazy and don't want to walk back into the office to slice!).
Do you use the glass side or the logo side on the Ender3 bed? I am having some crazy inconsistencies with mine. It will work perfectly for 5 or 6 long prints, then fail spectacularly and nothing will stick. I just flipped the bed to try the glass side, so we'll see how that goes.
