There's an issue with the bottom right flipper on my Getaway. It appears to work fine when you use it when the ball isn't in play, but when you actually make a shot the power is almost non-existent. The upper flipper works fine. If I try to hold the flipper while I actuate it, I can feel it working but it can't even raise the flipper from its rest position. I've changed the coil with no difference.
I got the game as a project and it had the same problem at that time. I rebuilt the game and the flippers about a year ago and the problem went away. Only recently it has come back.
Any ideas?
