Hi.
My Getaway is reporting "Check SW 85 Opto Made Loop". In the switch matrix, this is listed as SW84. On the diagram, SW 84 is Listed as Opto Made Loop, SW 85 isn't even labelled on the picture / diagram. Completely missing a label on the picture / diagram is the opto just beneath the mountain plastic of the ramp, I'm thinking this must be the actual Opto Made Loop switch, since when I test it it doesn't respond. Also, when I run the supercharger speed test, it reports a ridiculous "2". I don't think this loop is happening in 2 ms.
I've tried pulling J205/J206 and jumpering pins to test these, but that doesn't seem to work. The switch matrix gets wonky in some of the J205 pins, maybe this is why.
Can anyone confirm if the Opto Made Loop switch is the one at the right side of the supercharger, and tell me how to test it so I can figure out if it is a switch problem or a board problem?
Video of supercharger speed test:
Photo of what I think is the switch that is erroring, and I can't figure out how to test if it is switch or board that is the issue.
What I suspect is Opto Made Loop switch, with some variable and mysterious number in the manual
