Been digging into the getaway i recently picked up. Almost all of the 89 flashers were burned out. After replacing and going through the test to make sure they all work my left bank flasher(s) dont come on.
I swapped bulbs, i have continuity from both the red/white wire socket to the board and the blue wire to J126-6. I have continuity from the connector to the middle leg of Q30 transistor.
Ive read/watched a couple videos about testing transistors and Q30 seemed to check out with a reading of .55 across both legs to center.
Am i missing something? I seem to read a lot about transistors shorting "on" but never off. is it possible/likely thats the case? What commands the transistor "on" is it possible that failed?
When in diode mode on the meter and i go from the body to the left leg the flasher does come on. so im assuming the board circuitry out to the flasher is ok.
Thanks for any help!!
