My shooter lane ball launch coil assembly doesn't look right. It has a stack of washers under the coil bracket. Typically, the coil bracket is mounted inside the notched pocket that has been cut out of the playfield top.
On my Getaway, the bracket is larger than the notched pocket, so it's not screwed down flush with the bottom of the notched pocket. As stated above, the bracket has a stack of washers under it, so that when it's mounted to the PF, the bottom of the coil bracket is flush w/ the top op the PF, instead of flush against the notched pocket.
Is this correct?
