(Topic ID: 253197)
Getaway Randomly Resetting
By bbulkley
10 days ago
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 10 days ago by YeOldPinPlayer
#1 10 days ago
My Getaway randomly resets while I’m playing. It’s inconsistent and so far I haven’t found a way to reproduce it. Twice it happened when a ball had just drained (maybe both times it was multiball?) but I think it has happened other times. I’m not even sure where to start. I’m a software dev with some basic circuitry skills, so I’m coming at this from a debugging perspective. My first inclination would be to find a way to force it to happen. I can play for an hour with no issue, or have it reset immediately.
Any ideas?
#3 10 days ago
Oh wow - this makes a lot of sense. I'm ordering one - thanks!
#4 10 days ago
If you want to read about causes and other possible solutions the Pinwiki is great: http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Game_resets
The Kahr board is an excellent solution IF your 5v is dropping. If it isn't, I don't think it will help.
#5 10 days ago
I have noticed that the lights dim when the flipper solenoids fire - not sure if that's a symptom of under-voltage but it caught my eye.
#6 10 days ago
mine did this and I reflowed the cpu…….. good as new now
#7 10 days ago
Quoted from ccbiggsoo7:
Yes, the Kahr board won't fix the issue if that is the problem. Been there, done that.
He says his lights are dimming so he may be losing the 5v.
#8 10 days ago
Is there a way to verify the 5V issue first, or is it easier to just try the Kahr board?
#9 10 days ago
Quoted from bbulkley:
Yep. With a voltmeter. If it's intermittent, it may be hard to see at first.
Bridge rectifiers on the power driver boards are known to not last forever on these games. But it could be other things.
#10 10 days ago
Quoted from YeOldPinPlayer:
^^^^^ THIS.
I, personally, do NOT recommend the Kahr board as a primary (long term) solution. It's great to keep a game running on location or at a show but it's not a long term solution. I only have one that I use to keep any game that exhibits this problem running at the Northwest Pinball and Arcade Show. Once the show is over the problem is isolated, fixed and the board removed.
#11 10 days ago
Yes and yes. Your boards have test points. Check the voltages there.
Quoted from DumbAss:
You should. It's an improvement on a systemic WPC design flaw.
$ 8.50
