(Topic ID: 168957)
Getaway opto problem
By n1teowl
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by Kingpin22
#1 3 years ago
I'm having an opto problem that I'm hoping someone can help with. I moved my Getaway from the garage to the house and now the optos are not working. I get an error that says that I need to check Opto1, Opto 2, Opto 3...basically all of the optos. I checked the opto board and see that none of the LED lights are on. Should they be? Any ideas on what to try next? As a side note, some of my GI is out now, too. A seemingly random string of GI lights, e.g. top left sling, bottom right sling, bottom pop bumper. Thanks in advance for any help.
#2 3 years ago
Yes,the lights on the Opto boards must be on.
Check the connectors first-reseat these on the opto boards and these on the Power Driver board.
Check the fuses on Power Driver Board too.
Measure +12v on test point at Power Driver Board.
#3 3 years ago
^check the fuses. start with power.
#4 3 years ago
I wanted to make an update, I was able to fix the opto issue. When I put the head down to move the machine, it pulled on some wires, causing one of the wires on the main power board to pop out of the connector. I pushed it back down with a small screwdriver and was able to get power back to those boards which took care of the problem. Thanks for giving me a place to start.
#5 3 years ago
Thanks for the update, we can all learn from random issues like this.
$ 131.00
Cabinet Parts
Tilted Pinball
$ 8.50
$ 15.75
Cabinet Parts
Tilted Pinball
$ 279.95
Pin Stadium Pinball LEDs
