Again Zara, thank you so much for chiming in, your input is helping me figure out these issues. I made a small mistake after I did your test and recorded the readings. I do not have a issue with flasher # 17, it works just fine. However......
Your testing is different than what I did, below is a list of what I got doing it your way:
J125-
1: 0.524mV
2: 0.561
3: .442 * left slingshot flasher
4: X
5: .525
6: .419 * left ramp flasher
7: .545
8: .535
9: .530
J126-
1: .522 * Right bank flasher - this is ok!
2: .551
3: .436 * left slingshot flasher
4: .528
5: .423 * left ramp flasher
6: .525
7: .543
8: .542
9: x
10: 1.091
11: 1.091
12: 1.075
13: .966
J127-
1: .523
2: x
3: .533 * low diverter
4: .529
5: .530
6: .522
7: .529
8: .525
9: .522
J123-4: .545 mV *revolving lamp
J128 & J129 have no connectors on them
As for the flashers, I noticed a small drop in voltage (~.125mV) for the "stuck on" than compared to the working flashers. Does this give any indication of what could be wrong?
As for the solenoid diverter low, i will check for loose wiring. But what does low divertor do? When the diverter high solenoid is on, it opens the super charger track and when its off, the divertor closes it self. It feels like its spring loaded.
