Recently I bought a HSII. One thing I am a noticing is that the kickback doesn’t always send the ball to the saucer. I ended up replacing the plunger, spring, and sleeve. The coil is tight with no play. I’ve aligned the plunger to hit the ball dead center. It’s shooting to the saucer about 70% of the time. Ive read about bending the ball guide slightly but I’m not sure which way to bend. Sometimes it aims high and sometimes low. I’m pretty sure this is a common problem but I can’t tell if it’s cause by the ball guide or something else. Any thing else I should check? Thanks
