Greetings,
I'm running a Videogame Bar in a small town in Czechia and also started implementing Pinballs.
Last week I got a HSII (second revision I think), after an overhaul where they mainly did cosmetic stuff and changed the DMCB.
First few days it was running nicely just the shifter would intermittently stop working shifting up so I just check the solderpoints and reconnected the plug which fixed it.
(Aside from that he was just giving me a "switch 64 ramp" error but the ramp worked correctly)
Yesterday we brought our Space Station from servicing and after just 6 games (where both machines were connected to the same power outlet) the HSII just showed a scrambled mess on the DMD.
The game itself works correctly just the display is showing those "flames" (could upload a video of it aswell)
So I checked online while printing out the manual.
What I tried:
Reseated the flex/ribbon cables
Flipped them once to see if would change anything
Checked all fuses (once after reseating the ribbon cable F112 blew but after reseating not anymore)
LEDs checking out
Visual inspection for any blown/burnt stuff
Since the display is "showing" something and changing I guess data is coming through but the HC-voltages may be off?
Gonna measure it in like and hour but would like to know if anyone would have any input aside from buying a Color-DMD to cut out the Hc-circuit.
Benjamin
