You should replace the parts back to factory.
Coil strength info below. If you leave on the stronger coil on the top flipper, you'll break stuff.
Robert
Late Model Williams Electronic Pinball Game Flipper Coils (1990-Later, DC Powered Coils)
FL11753 used for small flippers, parallel coiled, "weak" flipper strength (Yellow coil wrapper) - power 9.8 ohms; hold 165 ohms
FL11722 "weak" flipper strength, parallel coils (Green Coil Wrapper Color) power stroke coil 6.2 ohms; hold flipper upright coil 160 ohms
FL24/600-30/2600 same as FL11722 except series round coils
FL11630 "standard" flipper strength, parallel coils, used on nearly all Williams system 11 pinball games (Red Coil Wrapper Color)
- power 4.7 ohms; hold 160 ohms
FL23/600-30/2600 same as FL11630 except series wound coils
FL15411 strong flipper, parallel coils, used for main flippers on Addam's Family, Twilight Zone, etc. (Orange Coil Wrapper Color)
- power 4.2 ohms; hold 145 ohms
FL11629 strongest Williams flipper, parallel coils, Used on most of the newest WPC system games (Blue Coil Wrapper Color)
- power 4 ohms; hold 132 ohms
