For about 2 week's I've noticed that my HS2 Super Charger has gotten SLOWER !! ( Not Good )
I cleaned All the Opto's on Each magnet ( No Sucess ) then
I noticed the Top rivet was Loose , I drilled out the bad 1 and Replaced with another . Also as the ball spins thru the Charger , if the Diverter Isn't in Just the Rite position you will Loose Speed .. I'm Full Speed now running in the mid 80's ... I continued working on the Position of the metal that the Diverter closes up against .. Check out my 2 video's of the Fix .. HS2 is a Keeper !!
