I know this has been discussed but it has been a couple years and I could not see an exact answer to these.
Couple problems with my Getaway HS2 related to this topic, can you help?.
(1) The shooter/launcher will not work.
Solenoid 12/Coil A-14789 Plunger Kicker will not work during Game Play or during Diagnostic Tests.
Coil circuit okay when I use a MM
Wire Continuity okay from J107 to Plunger Kicker solenoid
Fuse F102 is okay checking with MM
Does this mean it is probably the High Current Driver Board Assy? (see second picture attached) It did not look burnt anywhere. How do I test that board or how do I determine if that is the cause? Or what other things should I check?
(2) Introduces Additional Ball into Playfield
Prior to the Plunger/Launch issues, the game would often put an extra ball into the shooter lane mostly during the first ball, game start.
Switches 55,56,57,58, and 78 all test okay during Diagnostics (did with and without a ball in each)
I found this wire (with a diode) cut (not attached on one end). It is soldered in a tab held down by a bolt near the ball trough and hole in the lower right of the playfield I believe near switches 56 Left Trough and 57 Center Trough (see first picture attached--the wire with blue tape on it), where should the end of that be attached?
Thank you.
Dan
